1998 Explorer will not start
Old Jun 6, 2011 | 07:43 AM
SHIPPERMAN's Avatar
SHIPPERMAN
I have a 1998 Explorer that has been having starting problems. I was able to go to the outside relays and tap on them and get it started. Now, it is a no go. Any ideas?
Old Jun 6, 2011 | 08:29 AM
caseys's Avatar
caseys
xxxxxxxxxx
Old Jun 6, 2011 | 09:37 AM
SHIPPERMAN's Avatar
SHIPPERMAN
Originally Posted by caseys
How long have you been using the tapping method on the relays to start the Explorer...? Maybe it is time to replace the relays.
I tried that as well
Old Jun 6, 2011 | 01:01 PM
shorod's Avatar
shorod
Before tapping on the relays does turning the key to the start position result in a click of any sort, or the starter motor turning the engine over, or absolutely no sounds?
-Rod
Old Jun 6, 2011 | 02:48 PM
SHIPPERMAN's Avatar
SHIPPERMAN
It turns over very well. Just acts like it is getting no gas or something. I had my wife turn the switch on and I heard the fuel pump working
Old Jun 6, 2011 | 03:02 PM
aquanaut20's Avatar
aquanaut20
Isolate the problem, fuel or spark.
Inject a test fuel into the intake manifold (use a vacuum nipple) and if it starts momentarily, fuel is the issue.
Pull one of the HT wires use a spare spark grounded, you should see a good strong blue spark, if not spark is missing..Philip
Mobilmike1
Engine Swaps
May 29, 2017 09:44 AM
Susan Wade
New Member Introductions
May 18, 2017 01:37 PM
venmon2
Mar 25, 2017 05:49 AM
MasterPepe
Feb 23, 2017 11:55 AM
Matthew Redmond
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 5, 2017 10:36 PM
