replacing drag link
Old Jun 6, 2011 | 06:34 AM
rquinlans's Avatar
rquinlans
replacing drag link
93 f 150 , 2 wd , have to replace the drag link and the spindle on the end from the steering box , any tricks to keeping everything in position during disassembly and assembly so i don't have to have alignment after ? any pointers appreciated
Old Jun 6, 2011 | 08:18 AM
zxwut?'s Avatar
zxwut?
You're going to need an alignment afterwards. It's not expensive, so go ahead and work it into your budget.
Old Jun 6, 2011 | 10:45 AM
cj06's Avatar
cj06
pull the linkage off as a single unit then when you get the new parts put them together the same length as in make sure the new one is the same length as the old one and then put it on ! this will be a good starting point and i have done it many times with out needing a alignment !
Old Jun 6, 2011 | 09:47 PM
xxclaro's Avatar
xxclaro
Just did mine on my 88 4x4 on Saturday. I'll be putting it on the alignment machine to check the toe in but I think I'm still pretty close. The way I do it is to count revolutions when unscrewing it from the tie rod end. I make a white mark on it so it's easy to keep track of,then just count the same number of turns going back in. It'll get you close,anyway.
Old Jun 6, 2011 | 09:55 PM
rquinlans's Avatar
rquinlans
thanks guys ,
raymond71
Sep 6, 2013 03:07 PM
Big_Al59
Aug 13, 2012 09:39 PM
rmcgraw351
1978 - 1996 Big Bronco
Aug 3, 2012 09:41 AM
hink10
Jan 1, 2006 11:13 AM
50F2
Apr 30, 2003 11:47 AM
