Does anyone know the part number for the tie rod end that is fitted into the drag link and goes into the pitman arm? when I search, I can only find the entire drag link and not just the end. (the reason that I need just the end is because I have a 1979 bronco steering box and pitman arm on my 1971 ford pickup, the drag link is a custom length and not available. I am going to build my own drag link with replaceable ends on both sides but I cant find the part number for the end). thank you in advance for any help someone may be able to give.
3A131
Use this number and your correct year number at the Ford counter and you should be able to get the part you need. The base part numbers don't change but the year change changes the part number.
So go to Fordparts.com and look for a later model year part like 1990 then look at the illustration for the part you need.
