coolant injection?
Old Jun 5, 2011 | 10:25 PM
Roasted7's Avatar
Roasted7
coolant injection?
In the context of the water/meth injection setups, would a very slight leak in a head gasket make your truck run like a raped ape? I would think not because it would only hit one or two cyliders.
It was just a random thought I had. I have no idea how those injection setups work.
Old Jun 5, 2011 | 11:08 PM
dchamberlain's Avatar
dchamberlain
Head gaskets on these engines leak out, not in. There should never be vacuum in the cylinders to pull in water or oil.
Old Jun 6, 2011 | 12:44 AM
Roasted7's Avatar
Roasted7
I guess what I was thinking was that when the piston draws down creating vacuum it could pull in a tad little bit of coolant. I thought there was always vacuum on a down stroke compression on an up stroke.
Old Jun 6, 2011 | 01:53 AM
ljutic ss's Avatar
ljutic ss
No vacuum on a Diesel engine only on a gas engine. With a turbo diesel you are pressurizing the cylinder on the intake stroke.
Old Jun 6, 2011 | 02:20 AM
p-nut's Avatar
p-nut
Unless the head cracked like two of my engines did. One engine had cracks extending from the valve guide area into the seat and the other was cracked between the valve and to the exhaust valve seat. Both engines failed while towing and were replaced due to hydrolock.
Old Jun 6, 2011 | 07:45 AM
Roasted7's Avatar
Roasted7
That all makes sense.
LawF250
21
Sep 1, 2010 11:18 AM
BigF350
Jul 22, 2005 05:31 PM
bpatton74
Mar 6, 2004 11:21 PM
1 Big Mike
Oct 27, 2002 03:33 PM
Willie
Apr 16, 2000 07:15 PM
