Knock After Fire
Old Jun 5, 2011 | 09:20 AM
hawgystyle's Avatar
hawgystyle
Knock After Fire
So I was driving My 1997 F-350 w/ a 351 on the interstate when I started to loose power so i pulled over to the side, turned the truck off. Opened the hood and the spark plug wire seemed to of been resting on the manifold and melted in half. There was a little fire burning but it was easy enough to blow out. I get towed home and I replaced the wire and now I have a knock in the engine. Any ideas?
Old Jun 5, 2011 | 11:08 AM
timbersteel's Avatar
timbersteel
Perhaps pull the plug that was connected to that wire. Inspect for possible signs of damage to the tip/electrode.
Only other thoughts is that there was plenty of voltage going to ground when the wire melted in half. I'm unsure of what else could be underlying as a problem now. Hopefully other members will chime in with advice.
Old Jun 5, 2011 | 04:41 PM
lew52's Avatar
lew52
One plug wire will just cause a miss , whats the oil pressure.....
Old Jun 5, 2011 | 10:43 PM
'89F2urd's Avatar
'89F2urd
Can you pinpoint the area of the source.of.the knock? I.e. top end or bottom end? What does rpm do to the knock?
Old Jun 5, 2011 | 11:19 PM
hawgystyle's Avatar
hawgystyle
Well i'll replace the distributor and spark plug. and i'll check the oil pressure and RPM's when i get home. i had to get out of town for a few days but please keep the advice coming. everything is appreciated
Old Jun 6, 2011 | 08:37 PM
'89F2urd's Avatar
'89F2urd
dont start arbitrarily replacing parts. . .it will drive you nuts. figure out whats wrong then put your time/money where it counts.
Old Jun 6, 2011 | 11:01 PM
hawgystyle's Avatar
hawgystyle
Yeah, i just have to spend time lookin at it when i get a chance. just been too busy but thank god for having two trucks
Old Jun 7, 2011 | 09:32 AM
hawgystyle's Avatar
hawgystyle
Well i got to look art it and its coming from the upper half of the motor in the front.
Old Jun 7, 2011 | 03:49 PM
'89F2urd's Avatar
'89F2urd
have you ever heard a rod knocking? or a bad crank bearing knocking? how about a collapsed lifter "tap"? terminology is key when describing an irregular sound. . .they all have their own distinct sounds that, when heard by a familiar ear, cannot be mistaken for one or the other. if you have a "tap" vs a knock coming from the top of your motor, chances are you have a collapsed lifter.
again, what does it do with rpm? any power loss?
Old Jun 8, 2011 | 07:42 AM
hawgystyle's Avatar
hawgystyle
well now that i think of this it sounds more like a "tap".
Truck starts right away. i have no RPM gauge so I cant really see what its doing but otherwise it sounds like the RPM's are not fluctuating at idle and there really doesnt seem to be a loss of power when i give it gas.
MSM0075
18
Oct 5, 2008 09:16 AM
VQ2Fast4U
Jul 19, 2007 01:09 AM
Gr8ride
18
Apr 19, 2007 08:39 PM
nexmar
Sep 16, 2002 10:52 PM
