NEED SOME GOOD BALL JOINTS
Old Jun 4, 2011 | 03:41 PM
BLADE35's Avatar
BLADE35
I was thinking a servicable moog [ kinda pricey but if they last IDK]
or is there a comparable one for cheaper
Whats everyone going with thanx benny
Old Jun 4, 2011 | 04:19 PM
69cj's Avatar
69cj
Some times the saying " you get what you pay for" is true. I've always had good luck with Moog.
Old Jun 4, 2011 | 05:52 PM
wulfman's Avatar
wulfman
Hey benny like 69cj said you get what you pay for that being said dynatrac has some bad assss ones that are supposed to be rebuildable and if i am not mistaken you can rebuild them on the truck , i may be wrong on that one but think you can . But i think they are around 900.00
Old Jun 4, 2011 | 09:07 PM
BobsF350's Avatar
BobsF350
MOOG Are you pricing at the autoparts store or online at rockauto.com
Old Jun 4, 2011 | 09:21 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
DynaTrac ProSteers are $659
Dynatrac ProSteer Ball Joints
Old Jun 4, 2011 | 09:23 PM
bismic's Avatar
bismic
I am saving up for those!!
Old Jun 4, 2011 | 10:48 PM
BLADE35's Avatar
BLADE35
thanks for the replies guys
and I was thinking 80.00 a ball joint was high
it would be cool to be able to rebuild them on the truck but all I saw was it was rebuildable without any special tools
looked to me like you undo the bottom on the ball joint at the grease zert and then you can pull the king pin out the top.
you still need to separate the steering knuckel from the axel to be able to pull the ball joint apart.
the time saving is you dont have to press the ball joint out of the steering knuckel you just replace the guts when you get steering knuckl separated from the axel
659.00 is alot for ball joints
I will probably just roll the dice on the moogs
thanx guys
Old Jun 5, 2011 | 12:40 AM
amadas350's Avatar
amadas350
xrf ball joints are good, and very reasonable for the money.
Old Jun 5, 2011 | 07:10 AM
Ford428CJ's Avatar
Ford428CJ
I put a set of MOOGs in and very happy with them! But those Dynatracs are bad azz!
Old Jun 5, 2011 | 08:46 AM
69cj's Avatar
69cj
What ever you decide make sure that they are greasable!
Old Jun 5, 2011 | 11:46 AM
BLADE35's Avatar
BLADE35
man you know it. I wouldnt be doing this yet if they original were greasable the big tires and lift didnt help matters either. half or more my fault
Old Jun 5, 2011 | 02:07 PM
joe blow's Avatar
joe blow
MOOG for certain
Old Jun 5, 2011 | 07:55 PM
desertt5's Avatar
desertt5
Rockauto.com $23 upper, $54 lower. I just put them in, then we did an F-250 the next weekend. don't forget the seals.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
