Fule additive?
Old Jun 4, 2011 | 01:00 AM
SHERER6L's Avatar
SHERER6L
Fule additive?
I have a 2003 6 .0 and a mech. told me to add a qt of 10w30 oil to the fuel once a month. Said its good for it. Really?
Old Jun 4, 2011 | 01:31 AM
Dieselpop's Avatar
Dieselpop
Don't know about 10w30 but you can use 1 Quart of TCW-III 2 Stroke oil/fillup will quiet the injectors You can get it at Walmart it will not smoke where the motor oil will.
pop
Old Jun 4, 2011 | 07:55 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
I add the 2 Stroke from Walmart and Diesel Clean grey bottle every fill. A co worker walked by the truck one morning and made a comment at how quiet it was.
1 oz. per gallon of fuel. (2 stroke)
And these are my fuel filters after 15,000 miles of this.
Old Jun 4, 2011 | 08:22 AM
05whitef250's Avatar
05whitef250
I tried a new fuel all together yesterday...130 dollars worth of premium 93 octane gasoline DOH!!! First time in 10 years. But diesel kleen for me every other "normal" fill-up.
Old Jun 4, 2011 | 01:09 PM
smokersteve's Avatar
smokersteve
outch!!!!!!!
Diesel kleen and 2-stroke is great. I use 15-20 oz per tank, not 1oz per gallon, I think that is way too much.
Old Jun 4, 2011 | 01:24 PM
hubler13f's Avatar
hubler13f
So do you think it's the 2 stroke oil or the Tequila thats helping to keep the filters so clean?
Old Jun 4, 2011 | 02:13 PM
mah77's Avatar
mah77
I was running 2-Stroke and Diesel Kleen, but recently switched to Opti-Lube XDP. It's a bit pricier, but runs just as well, and fuel economy went up approx .5mpg. The XDP has second best (Biodiesel was first) on multiple tests for lubricity and cetane increase:
Test 1 (Diesel Power Magazine)
Fuel Additive Test - Ultra-Low Sulfur Diesel - Diesel Power Magazine
Test 2 (Independant Research)
Lubricity Additive Study Results - Diesel Place : Chevrolet and GMC Diesel Truck Forums
Old Jun 4, 2011 | 03:36 PM
amdriven2liv
The tequila just helps the process go smoother. Either way, Me and My truck run well.
The bottle actually had the water drain plug fluid in it.
Old Jun 4, 2011 | 05:30 PM
zhilton's Avatar
zhilton
I've been running Power Service for a couple of years (white or gray depending on climate) and noticed some decent fuel mileage improvement over untreated fuel. This is my recent fuel mileage with Power Service.Pavement Princess (Ford F-250 Super Duty) | Fuelly I just ordered a gallon of XPD, so we'll see what kind of change in fuel mileage I might see.
And with fuel that clean (I don't see any water) that's a good sign.
Old Jun 4, 2011 | 08:32 PM
BobsF350's Avatar
BobsF350
Lucas upper cylinder lube.
Been running it for years since they changed the fuel to ULSD.
180K original injectors and fuel pump
longview1
6.7L Power Stroke Diesel
56
Sep 16, 2014 01:55 PM
1969furd
Feb 17, 2014 08:13 PM
WALFORD'S 56
WTB - Parts & other
Aug 5, 2010 05:02 PM
oreocreaming
17
Jun 17, 2010 04:44 PM
StorminMarv
Oct 7, 2004 09:58 PM
