I'M IN TROUBLE
Old Jun 2, 2011 | 07:11 PM
timmyboy76's Avatar
timmyboy76
I'M IN TROUBLE
Guys, i need some help, big time. Just got back from river, this past monday, and noticed the truck was leaking oil. I crawled under and saw it leaking, when motor running, from the npt bar/pipe, for my oil pressure sensor. Its located off the oil cooler. Well, just crawled under it now, to fix it, thinking the teflon tape, wasn't enough, well, it wasnt that, its actually crackked, at the base of the threads. Not knowing that, i tried turning it, and BAM, the pipe broke. Know, i have the sensor in my hand, but the threaded part of the pipe, is broke flush with the threaded hole in the cooler.......what do i do, i'm really bummed right now. I sent the wife up, with my grandfather to get an E-Z out, but not sure, if i should go that route. I'm thinking, dump the oil and coolant, and remove the cooler. Any help fellas, be MUCH appreciated.
Old Jun 2, 2011 | 07:39 PM
snakedoc's Avatar
snakedoc
i think the e-z out first if that dont do it take it off and drill it out.
Old Jun 2, 2011 | 07:47 PM
Cell's's Avatar
Cell's
If it was my truck then I think I'd try the EZ-out first knowing that it might come out easy and then thread in a new one and be done with it . That is provided that I could get the EZ-out in there and make sure it can get a good bite at the broken part . Might be easier than you think .
Good Luck Fixing It !
timmyboy76's Avatar
timmyboy76
thanks Doc, just sketch'n on the thought of any debris in the oil system then. Think'n of filling up the oil pan til it bleeds off/outta the hole. This just aint right.
Old Jun 2, 2011 | 07:51 PM
bcaughhorn's Avatar
bcaughhorn
i think you are thinking to hard on it.id just use the easy out.
Old Jun 2, 2011 | 08:21 PM
timmyboy76's Avatar
timmyboy76
YEEEE HAAAA
Ur right, horn, ez-out has now, a spot on my workbench. Worked perfect. Not mess'n with the oil pres sensor for now, thru a plug in ur, and alls' good. Now i just need about a gal of oil. On a positive note, the trucks underbellys', nice n shiney.
Old Jun 2, 2011 | 08:22 PM
SkySkiJason's Avatar
SkySkiJason
I agree. Dont worry about 'debris'. Removing the cooler not that big of a deal if ya have to.
Old Jun 2, 2011 | 09:46 PM
DieselCamper01's Avatar
DieselCamper01
Glad you got it out Timmy. Good job
Old Jun 2, 2011 | 09:58 PM
snakedoc's Avatar
snakedoc
good to hear. i dont like to remove it if i dont have to.
Old Jun 2, 2011 | 10:04 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Good Job Timmy.
strokin'_tatsch
65
Feb 6, 2023 09:36 AM
walrus
Feb 4, 2015 09:33 AM
TheBlueMule
Nov 23, 2014 09:10 PM
billbot
Jan 13, 2014 09:29 AM
timmyboy76
Aug 12, 2011 08:37 AM
