300 parts interchange
Old Jun 1, 2011 | 05:46 PM
Rusty_Old_F250's Avatar
Rusty_Old_F250
Will a 390 flywheel fit on a 300? If not is there a flywheel for an 11 1/2 inch clutch availible for the 300?
Sam
Old Jun 1, 2011 | 07:22 PM
coolguy1419's Avatar
coolguy1419
flywheels are motor specific. 300 flywheel is internally balanced and like a 302, 351 are externally balanced. If you put wrong flywheels on you will get a heck of a vibration as the rpms go up. The 300 flywheel should be drilled for a 10 and 11 inch clutch.
Old Jun 1, 2011 | 07:47 PM
Rusty_Old_F250
If I read your post correctly, the 300 is an internally balanced motor? Same with the 390, so if the bolt pattern on the back of the crank is the same, and the diameter of it is the same it should work.
Sam
Old Jun 1, 2011 | 08:36 PM
F-250 restorer's Avatar
F-250 restorer
And if you hear a jack hammer starting, you'll know it's not correct.
Old Jun 1, 2011 | 08:46 PM
Rusty_Old_F250
That would be a warning sign for sure! I got lucky and swapping in the 4spd behind the 390 worked great, no issues. I'm just hoping I'll be able to use some of these new parts down the road when I put a 300 in the old pick-up. The local yards have a few running motors for about a $1 per cubic inch, so I might get my hands on one sometime in the future.
Sam
Old Jun 2, 2011 | 06:54 AM
coolguy1419
The 390 and 300 flywheels will be different weights and I'm pretty sure they won't work. I've been there and got the wrong flywheel before on an old 300 I had. Put it together fired it up and vibrated like crazy! Had to pull motor again to chain and put correct one on!
Old Jun 2, 2011 | 07:32 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
The 390ci FE engine is internally balanced like the 300ci(zero balance flywheel). Can't answer as to bolt patterns and fitment.
Old Jun 2, 2011 | 09:34 AM
f100jim's Avatar
f100jim
I doubt it would fit. The 300 flywheel has a 164 tooth ring gear. The FE flywheel has a 184 tooth ring gear. The FE flywheel is much larger diameter - it would likely not even fit inside the 300 bellhousing, and even if it did, you would not be able to install the starter.
Old Jun 2, 2011 | 09:38 AM
Harte3's Avatar
Harte3
"The 300 flywheel should be drilled for a 10 and 11 inch clutch." I think coolguy is correct on that...no need for anything but the 300 flywheel for either clutch.
Old Jun 2, 2011 | 06:12 PM
Rusty_Old_F250
Alright, thanks guys. Looks like it won't work.
Anyone out there make a flywheel that will fit an 11 1/2 clutch for the 300? I seem to remember one member on here saying he had one on the transmission and such he pulled from an 80-something f350. The clutch on the 390 is brand new (40 miles on it so far!) and I don't really feel like shelling out another $200 for another clutch if there's any way this one will work.
Sam
F-100project
Aug 27, 2016 06:34 PM
Biff61
Apr 23, 2016 01:52 PM
#1spudman
Aug 4, 2015 09:26 AM
Broomfieldbum
Sep 5, 2010 04:55 AM
todd jo
Mar 25, 2007 02:11 PM
