dot 3 or dot 5
Old Jun 1, 2011 | 08:56 AM
redbeard_trucks's Avatar
redbeard_trucks
dot 3 or dot 5
which brake fluid is recommend for these trucks?
mine is a stock 61 f100..
ps. when is the search function going to be restored??
Old Jun 1, 2011 | 10:19 AM
Mike G's Avatar
Mike G
Dot 3. If you do a complete replace of all the fluid, you can go Dot 5, if you wish...
--Mike
Old Jun 1, 2011 | 03:35 PM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust
--Mike
Dot 3 is now the standard, ands works great.
Dot 5 synthetic restists water accumalation, and is the best is you have the time to do it right.
Normal brake fluid is hydroscopic. Which means it absorbs atmospheric moisture which causes it to break down.
Old Jun 1, 2011 | 04:00 PM
tbm3fan's Avatar
tbm3fan
Supposedly you need to change out your system if you switch to silicon fluid as the two can form a sludge when mixed together. Very few OE manufacturers use Dot 5 anyway so why would you. I don't bother at all. A better fluid would be DOT 5.1 which is still a glycol base with a higher boiling point. That also means it's affinity to attract moisture is lower.
The simple thing to do is change out the fluid every year. Not as hard as it seems. First thing is I bought a large vacuum sump/canister system from Griot's. What a time and back saver that thing has turned out to be with 8 cars. Now I just pop the top on the master cylinder and use my old turkey baster to remove the fluid from it. Then I pour new fluid in and hook up my vacuum device. Pump it up to create a vacuum, open the valve and out comes all the old fluid in that particular line. Check the master, top off, and do for another 15-20 seconds before closing the bleeder valve and onto the next. Takes me about 20 minutes to do each year at the same time as an oil change on all the older cars.
Old Jun 1, 2011 | 09:05 PM
ddavidv's Avatar
ddavidv
DOT 3 is fine. I've talked to a lot of guys who have used synthetic DOT 5 and every one has wound up changing back to 3 for one reason or another.
Annual changes are probably overkill. Back before they really expanded the service intervals on new cars, the suggested frequency was every 30,000. Very few cars actually get this done, ever, and brake problems are pretty infrequent until you get really high miles and stuff wears out. The main purposes of flushing are twofold, IMO: one, to purge any water that's been brought into the system, and two, fresh fluid makes rubber parts happier. I've got a Subaru with 155,000 on it and the hydraulic clutch system is getting tired, but I've gotten longer life from it with more frequent fluid replacements (luckily, it has it's own reservoir).
F-250 WARHORSE
Nov 12, 2013 08:35 PM
supercab78
May 21, 2007 06:58 PM
bigredtruckmi
General Automotive Discussion
16
Apr 14, 2007 11:18 AM
Torstein
Jun 5, 2003 05:56 AM
olthunter
Aug 17, 2001 10:35 PM
