help with zf5 speed rebuild
Old 06-11-2012, 03:43 PM
stainlessstroker95's Avatar
stainlessstroker95
stainlessstroker95 is offline
I was needing help finding out what parts i need to order. I ordered the short throw shifter from jim last week, and this week i and gonna order a new clutch. The throw out bearing is really squeaking bad, and i wanted to replace clutch while i was in there. My prob with the transmission is some times it pops out of 2nd and it also grinds going into reverse. Im gonna get my parts from midwest trans also. This is for my 95 so it has the 42 in it. Thanks for your help.
Old 06-11-2012, 04:50 PM
Talyn's Avatar
Talyn
Talyn is offline
Honestly, Your gonna need a syncro kit, but you wont know 100% till you get it broke apart.
Old 06-11-2012, 06:29 PM
stainlessstroker95
Ok i should prob go ahead and get all of them then to do it right. I guess i need the bearing kit and the seal kit too. Is there a certain person i should ask to talk to when i call?
Old 06-11-2012, 06:57 PM
jmpape's Avatar
jmpape
jmpape is offline
I had similar problems on mine, grinding in low gears and reverse and popping out of second. IIRC, the grinding was synchros - I replaced. The popping was a worn shift collar (part that slides over the synchros and gears). Wasn't cheap...
How does the short throw work? Does it just replace the shifter?
Old 06-11-2012, 08:10 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Do the shift collars come in the syncro kit?
Old 06-11-2012, 08:18 PM
fordman67's Avatar
fordman67
fordman67 is offline
Prob not.that is usually a hard part.
Old 06-11-2012, 08:25 PM
baker1983's Avatar
baker1983
baker1983 is offline
Whats a short throw shifter cost if u don't mind me askin
Old 06-11-2012, 08:59 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Gabe, I've got a 42 torn down in my shop that had 5th gear busted in it. Let me know if you need anything
Old 06-11-2012, 09:01 PM
stainlessstroker95
Bill i was just wondering the same thing. The short throw kit shorten up the distance between the gears. There is a spacer and other stuff. It gives you more leavradge so you dont move the shifter so far. Pm dzljim or go to his rosewood diesel shop site for a price.
Old 06-11-2012, 09:12 PM
stainlessstroker95
Ok thanks bill! Im just not real sure what all is involved in the rebuild so i can get the part ordered. My father in law is gonna help me do the work. He has rebuild dodge tranys befor but didnt know if the fords were alot different. I guess il just have to wait like talyn said.
Old 06-11-2012, 09:14 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Old 06-11-2012, 11:58 PM
jmpape's Avatar
jmpape
jmpape is offline
My synchros did not come with the collar. I had to buy it separately
Old 06-12-2012, 06:35 AM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
If either of you (Gabe or Bill) need the rebuild tool kit for the ZF, let me know via PM. I picked one up real cheap for a project a few months back, then the project fell through.
Old 06-12-2012, 03:04 PM
stainlessstroker95
Ok thanks nate. What special tools come in the kit?
Old 06-12-2012, 03:14 PM
DZL JIM's Avatar
DZL JIM
DZL JIM is offline
PREMIUM SPONSOR
Adds riser to the shift tower where the shifter bolts to and replaces the shifter with a longer piece. This changes the fulcrum point thus shortens the throw needed to change gears.
Pm or email me if interested. I can't post cost in the open forum.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Quick Reply: help with zf5 speed rebuild
