cab lights
Old May 31, 2011 | 01:27 PM
KawiRider78's Avatar
KawiRider78
cab lights
im putting cab lights on my bullnose and the truck originally didnt come with them i was wandering is there some kinda template out there or does anyone have measurements thanks
Old May 31, 2011 | 02:16 PM
Coneynew's Avatar
Coneynew
I added cab lights to my 85 F350. If I can find the measurements, I'll send them too. I basically went to the salvage yard and measured 3 diff F-Series pickup until I was sure of the measurements. I wrote them down w/ a diagram (now to see if I can find them)
PS. Do yourself a favor to and grab a factory harness from a donor truck if you have not already, as these are plug n play.
Old May 31, 2011 | 09:21 PM
KawiRider78
thanks that would help alot
Old May 31, 2011 | 10:12 PM
AstroFab's Avatar
AstroFab
I went out to pull some measurements off my '83 F-250 with factory clearance markers, but it was too dark to see. If nobody chimes in by tomorrow, I'll try to get some numbers for you.
Several years ago I installed some on my old '96 F-250 that I swiped from a truck that a guy was parting out. After I removed them I started to take measurements, but then realized that I could pull a template. I ran a couple strips of masking tape over the holes from side to side, marked the holes with a pen, and made some reference marks at the rain gutters on the masking tape. Made my install very easy.
Old May 31, 2011 | 11:02 PM
da X-man's Avatar
da X-man
I literally just added cab lights yesterday.
From the drip rail to the center of the first light is 6.25 inches.
From center of light to center of light is 12 inches.
From window edge to front of light is 3 3/8 inches.
If you're wanting to tie them into the parking lights, its the brown wire coming from the switch
Old Jun 1, 2011 | 04:12 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
The connector for the factory clearance lights is located behind the drivers kick panel.
All trucks have this connector, if your truck came with the cab lights or not. You will just need the cab light harness extention wires from the connector to the lights, and to cut the holes.
Old Jun 1, 2011 | 01:42 PM
KawiRider78
da x-man arent the far right one and left one offset a little back like newer super dutys or no and can you put a pic up if you dont mind thanks
Old Jun 1, 2011 | 02:27 PM
da X-man's Avatar
da X-man
You're right. They are set back a little further... but they're all 3 3/8 inches from the windshield trim. The trim doesn't follow a straight line on the truck but rather curves with the windshield.
Old Jun 1, 2011 | 02:41 PM
KawiRider78
ok thanks alot for your help
Old Jun 1, 2011 | 02:45 PM
da X-man's Avatar
da X-man
No problem bud! Just be sure to have it measured exactly before you drill. Once you start, you can't go back.
Old Jul 25, 2011 | 07:30 PM
KawiRider78
are the single cabs have a 2 layer roof??
Old Jul 25, 2011 | 07:43 PM
81-F-150-Explorer
Yes, they have two layers of sheet metal.
The inner layer is what the headliner attaches to if equipped.
Old Jul 26, 2011 | 12:31 AM
KawiRider78
so its a pain to wire the roof lights in great
Old Jul 26, 2011 | 11:50 AM
81-F-150-Explorer
After the holes are drilled in the top layer, you should use something like a wire clothes hanger, (If you can get these even anymore) or some bailing wire and fish the wire(s) up the "A" pillar from where it connects at the connector at the "kick panel" location.
Shouldn't be real hard to do.
Old Jul 26, 2011 | 04:33 PM
ctubutis's Avatar
ctubutis
Originally Posted by 81-F-150-Explorer
After the holes are drilled in the top layer, you should use something like a wire clothes hanger, (If you can get these even anymore)....
Laundromats and dry cleaning services still have 'em.
Off topic I know but that's OK.
