shocks
I went thru some calcs to sort out front/rear shocks on the truck (not sure if it had a 4 or 6 lift when I bought it).
On a recommendation from a 4wd buddy that knows more about it than I do, I used factors of 40% for compression and 60% for extension, meaning that I anticipated that the shock would not compress or extend more than those factors for my usage. I use the truck on our property, trailering, etc, no extreme off-road with lots of high angles, etc.
I used Pro-Comp ES3000 shocks with boots, they seemed to work fine for my use, but of course everyone has their picks on shocks. Not interested in debating that, just giving an example of how I picked shocks.
If you look at the Pro-Comp site, they list specs for their shocks. I had a chart somewhere, easier than sifting thru many web pages.
Pro Comp ES3000 Series - Shock Absorbers - Shock Absorbers, Stabilizers & Accessories - Lift Kits, Suspensions and Shocks - by Pro Comp
As an example:
At ride height, the distance between top/bottom mounts on my truck was 24" on one set of the front shocks (have quad shocks on the front).
Looking at the specs, after some trial and error and looking at several shocks to get me generally in the 24" installed height range, there was a ES332010 shock that shows 31.76" extended, 18.25" compressed:
- this shock has 13.51" of travel.
- 40% of 13.51" = 5.4" for compression travel
- 60% of 13.51" = 8.1" for extension travel
- 24" ride height plus 8.1" = 32" extended
- 24" ride height minus 5.4" = 18.6" compressed.
This time around, when the truck is reassembled I will go thru the same process, especially since I'm changing the location of the rear axle shock mounts and also adding 2 more shocks in the back as well. In your case, if you are anticipating more dramatic off-roading you can increase the compression and extension factors.
Hope this helps. Maybe someone has a different and better way, this is what I did and it worked fine for me. <!-- / message -->
<!-- edit note -->
