Front shock Mounts
Old Nov 19, 2006 | 10:48 AM
Raymond Bourque's Avatar
Raymond Bourque
Front shock Mounts
Hi Guys,
My 93 F150 supercab has a bit of looseness at the lower shock mount (on the left front). What's your experience, should I change just the mount, or the bolt that holds the shock as well?
Thanks,
Ray
Old Nov 19, 2006 | 04:21 PM
alz's Avatar
alz
I know that when I replaced my shocks I reused my bolts. Afterwards, I had a noise from the front end. It turned out to be the lower bolts that mount the shocks. The diameter was a little worn and sloppy on the new shocks. I replaced them, and all was well again.
Old Nov 19, 2006 | 05:39 PM
lostin90s's Avatar
lostin90s
I have bought trucks with as little as 70000 miles that showed serious wear on bolt . 1 truck had 130000 miles bolt was worn half thickness. I now replace the bolts everytime I swap shocks. Good luck _
_____________________________________
94 F150 XLT 4x4 SC LB Maf 302 E4od
JLR1953
Mar 13, 2014 05:56 PM
publiuss
Aug 1, 2012 03:31 PM
godblessmud
Offroad & 4x4
Feb 3, 2008 07:26 PM
wbw189
Apr 17, 2006 02:51 PM
rwr
Offroad & 4x4
Sep 9, 2003 11:38 PM
