Headlight Assembly
Easy job. No more than one beer per headlight difficulty level...
The best upgrade is '02-'04 OEM 'clear lens' headlights ($100/<acronym title="Page Ranking">pr</acronym> used) and Hella 100/80watt bulbs with a headlight relay harness. (Get bulbs and harness from Susquehanna MotorSports - High Performance Vehicle Lighting and Competition Accessories for about $100).
The bulbs in the '05+ headlights are an epic POS design - don't waste your money...
For under $200, the combo I suggested blows any HID's currently available away AND doesnt annoy oncoming drivers!!
I really dont want to swap my 2000 lamps - have to pull the brushguard I think. Will the Hella work in the existing housings?
Or should I just eat the pain and pull the brushguard?
Thanks,
D.
I ran the 2000 housings and 80/100 bulbs in the X until I (screwed up
) put '05-'07 stuff on the dually and donated the clear housings to the X.I think the stock '99-'01 'fluted' lenses are dangerously weak. A minimum improvement would be a relay harness - then the higher wattage bulbs are a cheap upgrade from there!
Let us know how it works out for you.
[quote=SkySkiJason;11738771]Yes, the harness and bulbs alone are a BIG improvement. The newer housings are just that much more better.
