Need Help: 85 Ranger Hoses
Old May 30, 2011 | 09:28 AM
Siwon's Avatar
Siwon
Anyone know where these hoses go?
This is a 1985 Ford Ranger 2.8L V6 171 engine, 2 wheel drive 5 speed trans. Carbureted of course.
There is a hose coming from the EGR valve and another hose from something else and not sure what goes where.
I believe one of them goes to the plastic air intake thing.
Hose 1
http://yfhgaming.com/images/hoses/P1000055.JPG
http://yfhgaming.com/images/hoses/P1000056.JPG
Hose 2
http://yfhgaming.com/images/hoses/P1000057.JPG
http://yfhgaming.com/images/hoses/P1000058.JPG
Old May 30, 2011 | 11:24 AM
Old93junk's Avatar
Old93junk
The hose on the EGR valve should go right under the front of the carb on a port coming out of the carb/EGR spacer plate.
The first hose, I believe hooks to a vacuum device on the underside of the air cleaner.
It's been many years since I have seen a 2.8 in stock configuration with all those hoses everywhere, the length of the hoses should give you a good idea where they terminate.
Old May 31, 2011 | 11:12 AM
Siwon's Avatar
Siwon
Does it go to one of these vacuum ports? If so, where does the current hose that's already on it go to?
Port left of carb
http://yfhgaming.com/images/hoses/1-1.JPG
http://yfhgaming.com/images/hoses/1-2.JPG
Port in front of carb
http://yfhgaming.com/images/hoses/2-1.JPG
http://yfhgaming.com/images/hoses/2-2.JPG
Port on left valve cover
http://yfhgaming.com/images/hoses/3-1.JPG
http://yfhgaming.com/images/hoses/3-2.JPG
Port on back of carb
http://yfhgaming.com/images/hoses/4-1.JPG
http://yfhgaming.com/images/hoses/4-2.JPG
Old May 31, 2011 | 11:36 AM
Old93junk's Avatar
Old93junk
Need a little context.......Is this because of poor drivability issues?
The first is elect. choke wire, it's correct.
The second some kind of emiss. hose, also seems correct where you indicate.
The third, PCV valve vac. not certain at all.....probably anywhere you can obtain good vacuum.
The 4th, unable to see enough.
Have you considered doing the Duraspark swap and ridding your truck of all this 26 year old, probably non-fuctional emiss/comp stuff that is probably making your truck run poorly?
Old May 31, 2011 | 11:44 AM
Siwon's Avatar
Siwon
Duraspark swap?
I recently worked on the motor, putting new lifters, head gasket, valve cover gaskets and pcv or whatever has the 2 circles gasket.
The truck idles very poorly with the hose disconnected.
I'm certain that you are correct with the air intake hose and the first hose.
I replaced the lifters because there was a clicking, and it still clicks.
Old May 31, 2011 | 11:49 AM
Old93junk's Avatar
Old93junk
You realize the 2.8 is solid lifter engine?.........lifter noise is normal to a degree, muted ticking when valves are properly adjusted.
Is emissions testing mandatory where you live?....If not I strongly advise doing the Duraspark conversion (converting back to a earlier less trouble prone, Ford ign. system)
Old May 31, 2011 | 11:54 AM
Siwon's Avatar
Siwon
Never had an emissions test when I get my vehicles inspected.
Duraspark sounds good, what are the pros and cons? Do they sell them in stores like autozone or advance? I looked up on autozone and it didn't find anything when I searched for Duraspark.
Also, advance or autozone sold me Hydraulic lifters.
Old May 31, 2011 | 12:01 PM
Old93junk's Avatar
Old93junk
Pros are all there is to DS..........
Better mpgs
More power
Better reliability
Far more serviceable and simple
No more computer/emissions
Do a search in the Ranger and Bronco II forums here for DS conversion.
The rangerstation.com has excellent write up and diagrams in their 2.8 v-6 archives.
There is no "kit" available, parts must be gathered according to a list (You will see it on rangerstation write up)
Old May 31, 2011 | 01:52 PM
Siwon's Avatar
Siwon
I brought my truck to Berglund Ford Service place and they said that EGR hose goes to a little green hose which looks like an insulated wire without the wire inside.
Also bought some power steering fluid because it's real low!
It sure does shift smoother than it used to before I cleaned everything and replaced the gaskets.
I think the oil pan is leaking, going to have to check that out some time.
Some reason it smokes, looks like the smoke is coming from the chrome-like metal tube that goes under the plastic intake going to the exhaust manifold.
Could it be the Purple Power burning off?
sparkyrhett
31
Oct 13, 2007 09:24 PM
slammercb
Aug 12, 2007 07:27 AM
DaytonaTunnel
23
Dec 20, 2006 08:40 PM
Lance1601
Aerostar
Apr 14, 2006 02:41 PM
DougD
20
Aug 23, 2004 09:00 AM
