brake fluid leak
Old Oct 8, 2007 | 01:07 PM
sparkyrhett's Avatar
sparkyrhett
brake fluid leak
Went to my truck this morning, no brakes. when i parked it last night all was fine. i cannot find where it is leaking from. i assumed it was one of the line to the rear brakes, but fluid is everywhere even from atop the front fuel tank. is there anything above the lines that could be leaking the fluid. here are some images that might help explain. my truck is a 1991 fi50 305
http://i144.photobucket.com/albums/r...kyrhett/b1.jpg
http://i144.photobucket.com/albums/r...kyrhett/b2.jpg
http://i144.photobucket.com/albums/r...kyrhett/b3.jpg
http://i144.photobucket.com/albums/r...kyrhett/b4.jpg
http://i144.photobucket.com/albums/r...kyrhett/b5.jpg
thanks in advance for any advice
Old Oct 8, 2007 | 01:11 PM
nobodyspecial's Avatar
nobodyspecial
I am not sure what would make it start leaking all over at the same time, but I would just start replacing the lines - Its a safety thing as well, if its leaking in multiple places, they are probably about done in anyway, and if you replace a few leaky ones, the next time they go, you might not be so lucky as to be parked.
by the way, whats an fi50 with a 305?
Old Oct 8, 2007 | 01:39 PM
quicklook2's Avatar
quicklook2
just did my 95 sable brake lines.
no fun but the f150 is a little easier.
Old Oct 8, 2007 | 01:43 PM
sparkyrhett
josh: typo error 302
Old Oct 8, 2007 | 01:44 PM
nobodyspecial
yeah, I figured, but coulda gone the other way and been a frankenstein 350
You gonna start replacing lines?
Old Oct 8, 2007 | 02:54 PM
sparkyrhett
josh: that darn line is settled in the frame channal on the left side of the truck. i can't even see it. how do you go about removing it.
Old Oct 8, 2007 | 03:16 PM
nobodyspecial
It would help to know what year your truck is, not sure if things changed from year to year.
Old Oct 8, 2007 | 03:30 PM
sparkyrhett
josh: 1991 f150, 302, automatic
Old Oct 8, 2007 | 04:48 PM
nobodyspecial
Are you talking about the line that runs from the rear axle to the front along the inside of the frame rail? Do you have two tanks? I know that the front tank is close to the frame rail, so it might be a bit of a tight fit to reach up there.
Old Oct 8, 2007 | 05:12 PM
zzjonze's Avatar
zzjonze
Looks to me like you have a brake line rusted through. Like my 1987 did.
I replaced the line from the proportioning valve (along the frame rail) to the junction box on the real axel.
I soon had to replace all brake lines.Fix one another blows out, I wouldnt take the chance, just replace them all.
ZZ
Old Oct 8, 2007 | 05:29 PM
96onefifty's Avatar
96onefifty
the reason the tank looks wet is it is proably spraying from the hole in the line onto the side of the tank.
Old Oct 8, 2007 | 06:02 PM
sparkyrhett
thanks all for your support. yes, the line runs inside the rail from the rear axle to the front. i have two tanks. i did find two "unions" one before the leak and the other after. my problem is, i'm just a poor bloke that can't afford to buy the tools to remove the whole line with nut wrenches and flare tools. i think that if i can find the break, cut the line and insert a tube of sort over each end in place of the cut out, for the time being i can get to work in the morning. i know it is risky but my options are limited. wish all you guys were here, i would pass the beer around.
Old Oct 8, 2007 | 06:16 PM
quicklook2's Avatar
quicklook2
[QUOTE=sparkyrhett]thanks all for your support. yes, the line runs inside the rail from the rear axle to the front. i have two tanks. i did find two "unions" one before the leak and the other after. my problem is, i'm just a poor bloke that can't afford to buy the tools to remove the whole line with nut wrenches and flare tools. i think that if i can find the break, cut the line and insert a tube of sort over each end in place of the cut out, for the time being i can get to work in the morning. i know it is risky but my options are limit
that is not a smart or safe idea.
ride the bus.
borrow tools.
get a friend to drive you.
when the line leaks it is in usually a very weak and thin line and it would not be ok to clamp anything on there.
ask yourself this: do i see any other clamps anywhere on my brake lines?
NO!
so get with the program and fix it right.
Old Oct 8, 2007 | 06:17 PM
nobodyspecial
Originally Posted by quicklook2
ask your self this: do i see any other clamps anywhere on my brake lines?
hehe - sorry that made me giggle
Old Oct 8, 2007 | 06:20 PM
quicklook2's Avatar
quicklook2
glad you enjoyed that line.
