351w head size
Old Oct 28, 2006 | 09:20 PM
onefiftynut90's Avatar
onefiftynut90
351w head size
I have a stock 1986 f250 351w (and correct me if i am wrong) but I believe the stock heads are about 63cc chamber, with about a 9.1 --> 9.2:1 ratio.
My question is if i get a set of heads with a 60cc or 61cc chamber my compresion ratio will increase.
Will I need to run premium gas?
what kind of ratio am i looking at?
Old Oct 29, 2006 | 11:27 AM
baddad457's Avatar
baddad457
Reducing the chamber size 2 or 3 cc's will do nothing. To need to run Premium, you'd need to go up in the ratio about a full point and bump the ignition advance.
Old Oct 29, 2006 | 12:06 PM
Conanski's Avatar
Conanski
Depends upon the heads on your truck.. but stock should be 64-69cc producing about 8.5:1 ratio.. stock pistons are dished BTW. Dropping to a 60cc chamber will get you up into the 9:1 territory, but regular fuel should still be fine. My motor runs about 9:1 and has no problems with 87 octane.
majic
19
Feb 3, 2020 05:31 PM
gman97005
27
Feb 16, 2014 01:20 PM
1963f100
May 9, 2007 03:50 AM
biggman70f100
17
Jun 21, 2006 01:59 PM
