help. ac blower quit
Old May 29, 2011 | 08:34 PM
bigtexan99's Avatar
bigtexan99
Ac blower suddenly quit
On phone internet very slow
Where is fuse what should I check.
Thx
Old May 29, 2011 | 08:40 PM
snakedoc's Avatar
snakedoc
it is in cab box i think. my brothers did that and the brushes in the motor where dead he just put a new 1 in around $24.
Old May 29, 2011 | 08:43 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Check fuse 23 I believe it is in the cab fuse panel, also check the blower resistor pack to the VC side of blower motor.
Old May 29, 2011 | 09:12 PM
bigtexan99's Avatar
bigtexan99
Will chk . Ac still work. Feel cold,just no fan blower
Old May 29, 2011 | 09:15 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Fuse 22 is also one to look at it is the power to the coil on the relay for the blower to run also check the relay, I think you may be able to change it out with one of the trailer tow relays.
Old May 29, 2011 | 09:31 PM
bigtexan99's Avatar
bigtexan99
With engine off I can hear blower motor trying to turn when I twist fan ****
Old May 29, 2011 | 09:34 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Will it run on High ?
Old May 29, 2011 | 09:44 PM
bigtexan99's Avatar
bigtexan99
Won't. Blow at any fan speed.
Is fan blower controlled by electric signal or vacuum?
Old May 29, 2011 | 09:52 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
It is controlled by electric signal. Here is the print for your blower circuit.
Old May 29, 2011 | 10:19 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
We are probably looking at Matt's (snackdoc)suggestion the blower motor my of went south.
Old May 29, 2011 | 11:19 PM
bigtexan99's Avatar
bigtexan99
Checked fuse 22 & 24 in the panel, and fuse 23 in the power distribution box per the wiring diagrams. All fuses good.
Looks like its the resistor switch or the blower motor. Thanks for your help! Glad its not vacumn controlled so I don't have to hunt down a vac leak.
I'm home now, so will search the archives for any part numbers or test procedures.
Old May 30, 2011 | 12:44 AM
WA.Ranger's Avatar
WA.Ranger
www.partsguyed.com
Old May 30, 2011 | 09:20 AM
bigtexan99's Avatar
bigtexan99
It was the blower motor. 44 bux at O'reilly's.
Thx
To remove the squirrel cage from the blower motor, remove the locking end cap with a pair of pliers, then tap on the silver rod with a hammer while pulling the squirrel cage up and away from the blower motor.
The gasket will be a pain to get back on... I left mine off as I'm traveling and will put it on right when i have more time.
Old May 30, 2011 | 09:28 AM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Good Job glade you got it fixed.
spook222
Aug 11, 2016 10:32 AM
f150STX27
New Member Introductions
Apr 21, 2016 04:33 PM
f100today
May 19, 2014 07:43 PM
Tenderpaw
May 29, 2012 09:15 PM
sp21
1997 - 2003 F150
Aug 20, 2010 11:00 PM
