Help ASAP Again Please.
May 28, 2011 | 10:14 PM
Engine started up fine this morning and will not start now. I'm stuck... .the car sat all day... 65 Deg.
The 97 E 350 Diesel cranks well with lots off battery juice, but it will not turn over.
the odd thing is I'm not seeing my "wait to start light" turn on.
There is a little fuel in my vally of the engin.. not mutch.
I could use lots of help. Stuck ..
Thanks
If someone could call me for help That would be Great.
just now... odd thing I took Both Battery Grounds off and it started.. the stalled..
I still do not see my "wait to start" light come on..
I have notice this rig yesterday stalled twice while idealling..
Oil gauge comes up after cranking...Battery gauge look normal.
THanks
May 28, 2011 | 10:19 PM
I bet your fuel bowl heater is gone. Check your fuses. Try unplugging the fuel bowl heater, replace the fuse, and then try starting it.
Check fuse #22 under the hood. Also, do you have any tach movement when you crank? If you don't then it might be the CPS.
May 28, 2011 | 10:21 PM
Check your profile visitor messages.....
May 29, 2011 | 01:09 PM
I don't know where they are on a van , but check the small relay that powers the PCM . It may be loose or bad . you can use the horn relay for a test ...
May 29, 2011 | 05:27 PM
Horn Relay test?.... Are you saying honk the horn to see if the relay work?
May 29, 2011 | 05:29 PM
Scratch that horn relay comment I under stand
May 29, 2011 | 05:34 PM
Quote:
Originally Posted by
fordveggivan
That was funny!
These guys have you covered. You will be up and going again soon.
Thanks for the giggle!
momin
45
Sep 14, 2014 08:55 AM
rjp1965
Nov 3, 2011 03:28 PM
n2ojoe
Dec 31, 2010 05:24 PM
behoof
51
Sep 4, 2010 11:04 PM
fish_hunter2
13
Feb 19, 2010 11:00 PM
