Door Ajar Warning
Old May 28, 2011 | 12:20 AM
johnkirk's Avatar
johnkirk
Door Ajar Warning
2003 Navi. Door Ajar warning is going on randomly which turns on all dome lights. While driving It literally will go off every few seconds with an audible beep warning sound. Its driving me nuts. I have repeatedly slammed all of the doors & it doesn't help. I'm not sure where the door sensors are located but I am guessing that I have either a short, loose wire, or dirty door sensor.
Any help is greatly appreciated!
Old May 28, 2011 | 06:25 AM
alwaysfords41's Avatar
alwaysfords41
Hose down all the door latches including the liftglass with WD40. Open and close the doors a bunch of times. If it doesn't work, do it again.
Old Jun 2, 2011 | 06:50 AM
MP&C's Avatar
MP&C
And when that doesn't work.....
https://www.ford-trucks.com/forums/1...t-process.html
Old Jun 3, 2011 | 10:26 PM
robert_l_ross's Avatar
robert_l_ross
Smile Same
Mine did the same but only in the heat. Dealer said first they couldn't reproduce it...after 3 days got mad and went to the service manager and he said they could look at it in the codes and claimed he found three door sensor notices. Think he was telling the truth since it was a warranty fix - no money to be made by me.
Get it fixed though...in some states it is illegal to run your interior lights (interior lights, not map lights) at night and if that is your state you could get a ticket.
Old Jun 5, 2011 | 08:30 PM
lovemyexpy's Avatar
lovemyexpy
I had a similar issue myself. I finally determined it was the rear lift-gate latch. It would consistently latch, but wasn't consistently latching all the way thus leaving the dome light on. I sprayed it with some WD-40 and worked it with a screwdriver, repeating that process multiple times, and finally got it working smoothly. It hasn't given me trouble for about a year so all is good now.
Old Jun 6, 2011 | 07:50 AM
Icefan71's Avatar
Icefan71
WD-40 worked for me. Only I didn't just spray the latches.I sparayed the crap out of them. A good steady stream for at least 10 seconds on all 4 doors and the hatch. That was like 2 years ago. I haven't had a problem since.
Old Jun 9, 2011 | 09:51 PM
johnkirk's Avatar
johnkirk
Door Ajar Warning
So I sprayed inside the door where the lock mechanism is with WD-40 & my problem is fixed!
Machman
2009 - 2014 F150
Feb 22, 2025 08:35 AM
shteve.be
Jun 6, 2017 08:48 AM
Canuckbird74
May 15, 2017 10:38 PM
Canadiancowboy
Feb 9, 2017 08:07 AM
GlennTX
2009 - 2014 F150
Dec 14, 2016 10:50 AM
