Front Splash Shields
Old Feb 7, 2019 | 03:16 PM
MrQuick's Avatar
MrQuick
Originally Posted by Kalve
Was thinking of adding them to my 74 250. Is there anything you need to buy to make them fit or anything I might want to use when installing them?
good question... bumping for hopefully an answer.
Old Feb 7, 2019 | 04:27 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The splash shields were introduced in 1976 F100/350, could be retrofitted to 1973/75's.
Old Feb 7, 2019 | 07:43 PM
bulldogcountry1's Avatar
bulldogcountry1
Originally Posted by tbear853
I even have a pair for the rear .... aftermarket natch. I always thought they were a good idea.
What did you use for the rear? I've read here about guys using the front splash shields for the rear...after some cutting. I've never seen pics, though. I've been thinking about getting another set and trying it because those small factory pieces don't make me happy.
Old Feb 7, 2019 | 08:38 PM
azroxx's Avatar
azroxx
Alternate years?
1976/79 F100/350 & 1978/79 Bronco:
D6TZ-16102-A .. Right Front Splash Shield / Obsolete.
GREEN SALES CO. in Cincinnati OH has ONE = 800-543-4959.
D6TZ-16103-A .. Left Front Splash Shield / Obsolete.
No Ford Dealer or obsolete parts vendor has any.
Do you have information as to what years might interchange after 1979? I do have a set from a 75 that I am saving, have seen plenty of 80's models with fender liners in my local junkyard but have not wanted to spend the 20 bux to find out if they would "fit".
Old Feb 8, 2019 | 12:21 AM
NumberDummy
... None ...
The splash shields were factory installed on 1976/79 F100/350 & 1978/79 Bronco. Could be retrofitted to 1973/75 F100/350.
The entire truck changed in 1980, no frame and body parts were the same, so no splash shield from a 1980 thru today truck or 1980/96 Bronco will work.
Old Feb 8, 2019 | 05:22 PM
MrQuick's Avatar
MrQuick
thank you sir. I had assumed they could. Would i have to drill holes in the fender lip?
Old Feb 8, 2019 | 05:34 PM
flowney's Avatar
flowney
Yes, there are/were screws that went through holes on the fender lip and into the plastic splash apron to secure it.
I have a nasty looking pair that I removed from my "77 parts truck that I hope to use on my '76 F-150. However, I might be interested in a good repop if such a thing is available at a decent price. Anyone know?
Old Feb 8, 2019 | 05:41 PM
MrQuick's Avatar
MrQuick
LMC list them for both sides now..... not cheap about $140 each.
Old Feb 8, 2019 | 06:24 PM
four-sixty-power's Avatar
four-sixty-power
Wow, they actually did go up to 140 EACH, just looked at the online catalogue, but that is a lot of oil based plastic to make that piece so...
Old Mar 2, 2025 | 10:18 AM
tbear853's Avatar
tbear853
They are aftermarket ones formed for the rear, bought them from J C Whittney in the '90s.
Old Mar 2, 2025 | 10:20 AM
tbear853's Avatar
tbear853
They are aftermarket ones formed for the rear, bought them from J C Whittney in the '90s. I know, late reply but it might answer for someone. I just was browsing and saw his question just today.
Thorium
2015 - 2020 F150
33
Dec 31, 2016 01:19 AM
yankeerebel
Oct 29, 2016 07:41 PM
clintonvillian
2004 - 2008 F150
Jun 7, 2016 08:03 AM
cwendel
2009 - 2014 F150
Aug 13, 2012 08:43 PM
Shernius
1997 - 2003 F150
Dec 8, 2010 07:40 PM
