Well...I DO have 2.75 rearend....now what???
Just verified with 20 turn method...20 turns, 27 1/4 turns of drive shaft... 2.75 geared rearend. Feels lower...I'm turning 31" tires too. Guess the 400 is torquey! lol.
So what is amiss here. Maybe my timing is way off...or need a good tune up or different jets in the carb. My tail pipe is very sooty...I was told with todays gas that can not be a sign of anything...I think he is wrong. SURELY with this rearend and these tires I can do better than 9mpg.
Headers would help with the breathing but will they get you over 9 mpg? Not sure.
- Go on a diet... Remove whatever is not needed. A loaded tool box does not help. Easy mods is to remove the tailgate and rear bumper. Out of curiousity, I just weighed my 70's dock bumper and it's 80 lbs!
- Be mindful of your driving style - anticipate/coast to red lights and stop signs, accelerate smoothly, and avoid extended idling.
- Auto trannys are inherently inefficient with slippage and heat. A manual tranny (1:1 fourth gear) may eke out maybe 1 to 2 mpgs. Overdrive? A 2.75 is too low (numerically) for OD unless all you have around is flatlands. Even then, the engine won't be working at its most efficient RPM.
- Aero improvements? These things are bricks and the frontal area is humongous. A possible mod is to block off portions of the grill that don't aid cooling. The radiator opening is smaller relative to the entire grill area so there may be a teensy bit of benefit. A 2WD may benefit from an air dam to channel air or block air from going under the rig and creating turbulence.
- Fuel injection - A definite possibility. Then the engine is getting only what it demands. Again, a cost ($) to benefit (MPGs) analysis is required. Run some numbers on how many miles would be needed before it actually starts paying back.... For example, at $4 per gallon and 9 mpg, it costs 44.4 cents per mile (OUCH). Assuming it gains 2 MPG with EFI, then a $2,000 EFI system would require about 4,500 miles to recoup the base cost... But 4500 miles at $4 per gallon and 11 MPG is still over $1,600 in fuel alone.
Well I had posted some other threads about this but didn't wanna change the subject in them. I have a 400...with a 351m that is avaiable for parts. It WAS a hot engine...has dual plane intake...cam and such. This began as me wondering if it would be worth the time and money to put a 300 and small block C6 in....may be leaning towards that still. The 2.75 rearend would cruise right in the 300's torque range.
I have an 80 F150 that came factory with a 300, C6, and 2.75 rearend. I also have 31's on the back. It's a decent combo for MPG, but it's not the greatest for towing. It towed much better with the 235/75-15 rear tires.
MPG can vary between 12 and 16, depending on how I drive, what I haul, and how windy it is.
I will either go to a lower rear gear, or smaller rear tires.
9mpg doesnt sound too far off for your 400 and 2.75 gears and 31in tires. I'm runnin a 351m, 2.75 gears, and 265/75-15 tires, and get about 13-14mpg, if i'm not heavy on the gas. If yer blowing visible black smoke, then i'd be concerned with tuning the carb to lean it out a little. It wouldn't hurt to use good quality plugs as well. I don't use the plain copper, but the mid-range/cost plugs. Something else i didn't see mentioned is that i really do get more mpg with real gas, not the ethanol mixed crap. I run pure gas in my vehicles only. It costs a few cents more, but my mpg is better, so the cost evens out. And the real gas does not eat away at my rubber fuel components, unlike the ethanol mix.
chrisb_93
15
08-19-2014 09:18 PM
thunderb
17
12-10-2007 11:36 AM
six7seta
16
02-02-2005 06:04 AM
78bigblock
10-28-2002 09:17 PM
