hunting for that rearend
James,
I could take the low road on the title of this thread - but I won't.
I know there are folks out there that have this stuff memorized, but they may not see your thread for a couple of days. It can also take some time to type in the info so you have it. One thing that can help you out is a search of the forum (I know there are at least two threads with tons of rear axle data, plus a tech article) and, believe it or not, a general search of the web. I did a quick Google (www.google.com) search and came up with the following web site: Drivetrain.com. There is an awful lot of information there and it's certainly not the only web site.
So, until somebody who knows this stuff can find a minute to give you a hand, you might be able to get the answer with a little browsing. Good luck and I hope this helps a little!
Originally Posted by Earl
James,
Originally Posted by six7seta
well i pulled out an old 9'' rearend that i had laying around to put in my truck, but saw that its was a 2.75.... so im now on the hunt for a 3.25, 2.50, 3.89, or 4.11 rear end at the junk yard... anyone know which ford car/truck had those? PLEASE HELP ME!!!
I think I am looking for a very low gear ratio like 2.5 or 2.75. If you where in the San Jose, CA area I would buy your 9" if you found what you where looking for.
I'm going with a 3.00 under mine. I figure the 390 will get it moving just fine and give me some nice highway driving. My '91 Mustang GT has a 2:73 rear and I like the way it moves out and runs at 70-75. That being said I may have a set of 9" 3.25 R & P in one of my cabinets if anyone needed them. I'll check tomorrow.
Ron
Ron
Originally Posted by Jag Red 54
I have 3.00 in mine behind a c-4. I traded out the 3.50 R&P because the freeway rpm was too high. I'd rather have the better mileage than the jackrabbit starts. John
on
Originally Posted by boilerbots
Since I have a diesel I figure I better look for something really low. Where should I look for 2.50 or 2.75, a luxury car like a lincoln?
Since large displacement engines have more torque the rear end ratios tend to be taller. Look for something with a 400+ cubic inch engine in it and you will be more likely to find the ratio you want. A lincoln would probably be a good choice.
Vern
