Need advice, cost estimates
Most of these old trucks will require some work to get them driveable & safe. The most common projects are - Improve braking by installing a disc brake kit up front & a two chamber master cylinder & replacing brake lines, Improving highway performance by putting in new gears out back &/or replacing the rear axle with a 9 inch, Rebuilding your front axle with new king pins, tie rods, etc so it steers better & doesn't wander.
If you go the modern upgrade route - replacing engines, mustang II independent front suspension, it's like pulling a string & you end up replacing all sorts of things & it takes forever. (MY personal experience).
You have that rare opportunity with all the original drive train to rebuld it to better than new & get it driving much quicker. Good luck over there.
Ben in Austin
My uncle told me that the truck has 15 inch wheels on it. He did not tell me the size of the tires. What modern day equivalent should I run on the truck.
I have decided against reproduction wide whitewalls for the present because of the cost. I might do that a few years down the road. I first want to concentrate on other matters, engine, transmission, etc. However, the truck must have a set of new tires. What size (78 series, etc.) and type (radial, etc.) would you recommend that I can get economically at my local tire store?
I need a specific size because my tire man asked me what I wanted. Anyone know what the trucks originally came with?
Also, the VIN begins with a 9 and the truck has a 3-speed in the floor. That tells me it is a 1949 but it is licensed as a 1950.
I want to correct the title. Am I correct that it is a 1949?
Both 1949 and 1950 truck serial numbers started with 9. The consecutive unit numbers were a continuation for the second year, 1950. If your truck is titled as a '50, don't make a big fuss and go with it, 'cause it probably is one. Early '50's had 3 speed floor shifts for both the heavy and light duty transmissions. Later, toward the middle-end of 1950 production, the light duty trans was changed to remote column shift, while the heavy duty was still in the floor. You can't use that as a deciding factor. If you post your full serial number, mtflat (Tim) may be able to help you narrow down your build date a bit closer. He's been collecting that data on '49-50 trucks for several years. There's also a series of numbers stamped on the firewall that will be important, too, so post those, as well.
You can replace things as you go and they will fit back nicely.
unless you have the skills and equipment you can put anything you want on that truck.
I dont have the skills btu I am learning.
I bought my truck with a different engine in it and Thank goodness the PO didnt do a horrible job,All I have to do is improve/fix the little things he did.But is a pain in the butt to go to the store and ask for parts especially with the people working there now a days.
I vote for keeping the flathead they just look and sound right for your truck.
Especially since its going to be an occasional driver.
Good luck and post some pics
I have a 55 pickup with all late model stuff, and a 46 mercury car all original. I have driven the mercury on a 3,000 mile trip with no issues and would drive the 55 the same distance. The only thing about the 55 is it has ac so in hot weather be more comfortable. Keep in mind they drove these old trucks across the country when they were new, you just have to adjust your driving habits. There is nothing like a good running and driving flathead.
Good luck what ever you decide but these things are not cheap, not matter which way you go they are time consuming and expensive to build, but well worth it in the end.
The C4 conversion is very worthwhile behind the flattie.
And be aware that the rebuild cost on a flattie can very quickly add up, i personally think around the 5k is pretty close. A friend here recently spent $4800 and still has a ways to go with intake and heads.
Like others have said, it costs more than you think and takes even longer BUT its all worth it in the end. John
