rough Idle from a 300
Old May 25, 2011 | 03:48 PM
84GOAT300i6's Avatar
84GOAT300i6
As some of you may know I just rebuilt my 1986 f150's motor and I have put about 600 miles on it since my last post. The truck drives fine lots of power and runs out well. The only problem is that It has a really rough idle. When I rebuilt this motor I converted it to the Dura-spark 2 and a Autolite 2100 2 barrel carb, so there is no computer control at all on the motor. The plugs are new the wires are new the cap button and dizzy box are all new, and the carb was rebuilt before we put it on. Any ideas or help in this matter would be great!!!! Thanks in advance!!
Old May 25, 2011 | 04:57 PM
billt28's Avatar
billt28
have you checked for a vacuum leak?
Old May 25, 2011 | 05:36 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
With the vacuum leak already mentioned. Check Brake booster etc...
I'd say you need to adjust the carb. Running too lean or rich at idle perhaps?
A bad spark plug could also cause it.
Are the new plugs, wires, cap and rotor Motorcraft, or are they Chinese Quality?
Autolite hasn't been a Ford Brand since 1972, when the US Govenrment told Ford to sell off Autolite as it was a "monopoly". This is why Motorcraft came to be in 1972.
I've gotten bad Autolite plugs right out of the box.
Also something you might check... How is the compression? If the engine is unbalanced it can give it a slight "wobble" as the firing order is... 153624.
Old May 25, 2011 | 06:26 PM
billt28's Avatar
billt28
Pull the codes first thing.
Old May 25, 2011 | 06:56 PM
81-F-150-Explorer
No computer... He did a DS-II conversion, with an autolite 2bbl carb.
My first instinct is it's running too lean at idle. Carb Adjustment.
Old May 25, 2011 | 07:14 PM
84GOAT300i6
I will look at the carb tomorrow. Might spray some carb cleaner on the intake and carb to see if there is bad gasket causing a vacuum leak. I don't think its out of balance because I have been around engines that were in the past and the shake like a jack hammer when you give them a little gas lol.
Old May 25, 2011 | 09:09 PM
billt28's Avatar
billt28
Also check the vacuum line tree. Sometimes the caps develop small cracks in them, and allow air to leak.
Old May 26, 2011 | 02:34 AM
TheKirbyMan's Avatar
TheKirbyMan
Check your timing. Mine used to be off just a bit on my 302 and it had a bit of a stumble to it. You could hear it in the exhaust too. An adjustment on the timing took care of that, as well as having the air/fuel mixture correctly set.
Old May 26, 2011 | 08:13 AM
Greyf100's Avatar
Greyf100
Have you tuned the carb / timing with a vacuum gauge? How steady is the needle on teh gauge while idling? What's your reading at Idle?
Old May 27, 2011 | 03:47 PM
84GOAT300i6
I dont have a Vacuum gauge. I replaced all the plugs today and tuned the carb some more. it seemed to have helped just a small bit. Could my Dizzy be going bad it was a used unit that I got with all the dura spark parts from the donor truck. I'm at a loss.
Old May 27, 2011 | 11:31 PM
Greyf100's Avatar
Greyf100
get a vacuum gauge, it will help you diagnose instead of just throwing parts / cash / time at it.
$25 @ autozone.
Actron/3 1/2 in. face display 0-30 in. vacuum and 0-10 PSI pressure tester kit (CP7803) | Vacuum Pressure Tester | AutoZone.com
or they rent them...you pay $25 and when your done with it they give you your money back.
You also use a vacuum gauge to set the carb up and set timing.
Old May 28, 2011 | 12:53 PM
81-F-150-Explorer
A vacuum gauge is a good tool to have.
Old May 28, 2011 | 07:09 PM
ljfordman's Avatar
ljfordman
My inline 6 does the same thing especially after removing all the emissions stuff from the engine. I was told some time back from a retired Ford mechanic that Ford went through alot of trouble getting the right distribution of vacuum to smooth out the inline 6 and the 1bbl carb (which is why they installed Carters without any mix adjustments, ie., don't mess with it), and since it is inline you will always get a slight rocking to the engine. Since you now have a two barrel, you are getting even more air into the system, so I would try to rich it out a little, and reset the timing a degree or two off to compensate, but you may never get it 100%, in my opinion.
Old May 28, 2011 | 10:28 PM
oldschool84f150's Avatar
oldschool84f150
checking with vacuum gauge
How do I check the carb adjustment/timing with that vacuum gauge. I put a new/rebuilt carb on my 84 150 with a 300 last year. Now I am having the rough idle problem also. I pull up to an intersection or light and the idle drops down after a few seconds and almost seems like it wants to shut off. The other thing is how do I check for a vacuum leak with the gauge. I will be picking one up along with a new heater core that just decided to go out on me today.
Old May 29, 2011 | 01:20 AM
Greyf100's Avatar
Greyf100
Classic Inlines
