Sponsored by: Real Truck
4x4 Auto lock disassembly?
Old May 24, 2011 | 11:41 AM
kidoo's Avatar
kidoo
Hi, can we disassemble the 4x4 auto lock on a 2006 F350. I would like to clean and grease it. This one is different that the previous years, I think it is like that since 2005. If we cannot, how do we grease the inside gear?
Which lubricant should we use? I have this thread but there is not enough explanation.
https://www.ford-trucks.com/forums/9...th-pics-2.html
Old May 24, 2011 | 12:24 PM
2000silverbullet's Avatar
2000silverbullet
Check out this site:
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
Should get you going in the right direction.
Old May 24, 2011 | 01:17 PM
bpounds's Avatar
bpounds
The hubs have been redesigned since 2005, and I don't know how much help Guzzles site will be. Maybe a little.
I thought that was a pretty good thread on the new hubs. What other info are you wondering about? As for grease, I used Mobil 1 Synthetic grease in mine. I think it will be good at low and high temps. Seems to be working fine for me. Although it turned out that my real problem was the vacuum valve module, which was an easy swap.
Old May 24, 2011 | 03:13 PM
kidoo's Avatar
kidoo
OK, I see now, I saw a spring in there, which I did not see on mine yet because it was not taken apart. There is also some kind of bended washer too? Seems like the needle bearings are free on the ring?
The tin collar seems to be krimped to the rubber?
My 4x4 works fine, I wonder if it is necessary to take it apart like that? Maybe just soak it in varsol, air it, then regrease, but will this be enough to get the grease everywhere needed?
Great info, thanks,
Old May 24, 2011 | 03:50 PM
bpounds's Avatar
bpounds
I know I wouldn't take mine apart unless there was a problem. There are some small fragile parts inside that would be easy to bend or damage. The springs that snap to LOCK and UNLOCK position are very small. I think you can work all the grease it needs into the gears and bearing without taking it apart. And don't use too much. You don't want it to get sucked up the vacuum line.
Old May 24, 2011 | 03:53 PM
06Superduty's Avatar
06Superduty
Here is a link to the newer hubs. You need to scroll down.
Should help you. Good luck
https://www.ford-trucks.com/forums/9...with-pics.html
Old May 24, 2011 | 05:05 PM
kidoo's Avatar
kidoo
OK, that is what I will do, just clean it, let dry, regrease. But for the needle bearing, I wonder how I get get grease in there, maybe a point greaser?
By the way, the circlip down in the hole to remove the hub, I tried to remove it but that clip is some hard to split, could not get it out, so my vacuum leak will wait, may be I will never repair it before I have something else to fix pass the hub.
wizkid00104
Apr 28, 2025 09:26 AM
Watcher58
Mar 14, 2015 11:33 PM
willeo6709
16
Sep 4, 2014 07:45 AM
FordRun
Jul 27, 2014 12:39 AM
HiZ
Apr 14, 2014 07:15 PM
