How to Service the Selector Knob on 99-04 Hubs - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 1999 to 2016 Super Duty
Reload this Page >
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-10-2014, 09:33 PM
wizkid00104's Avatar
wizkid00104
wizkid00104 is offline
wizkid00104 has a great reputation on FTE.wizkid00104 has a great reputation on FTE.wizkid00104 has a great reputation on FTE.wizkid00104 has a great reputation on FTE.wizkid00104 has a great reputation on FTE.wizkid00104 has a great reputation on FTE.
How to Service the Selector **** on 99-04 Hubs
I'd like to thank Jason (1975stroppebaja) for the great article write up on servicing the hubs. What I have listed below is an addition to his article. 2004 F250 ESOF Hub Service
My truck is equipped with ESOF, but the auto hubs have long been replaced with the manual counter parts. From Jason's picture, dis-assembly should be the same for the auto hubs as well.
My driver's side hub was very hard to turn. Once I removed the guts from the hub, I sprayed some PB Blaster in the know as the article states and began to work the ****. I turned the **** past lock by a 1/4" until it clicked. I then noticed the dial began to pop out. With a little wiggling, the **** came right out.
On the passengers side hub, I lined the **** up and tapped it out from the inside with the wooden handle of the mallet.
I cleaned the hub housing out with brake cleaner and the greased the inner surfaces where the **** contacts the housing.
Then I removed the rubber seal on the ****. This is the culprit for causing the ***** to seize up.
I greased the **** with Valvoline Synthetic Wheel Bearing Grease and the placed the gasket back on. Notice the groove in the gasket. The groove MUST face outward. If you have it backward, you will find that the **** does not want to go back in.
I noticed on my drivers side hub that even after greasing, the **** was still very tight. I found that the hub was actually dented. Someone hit it with a hammer at some point . I ground the upper lip of the hub where the gasket makes contact. After some trial and error, it all fit together and turned nicely.
Here is the exploded view. The piece in between the hub housing and hub **** drops right into the housing. There are tabs on it that drop into the notches in the hub housing.
The **** has (1) large tab and (2) smaller tabs. Make sure these line up in the hub housing. This will make the indicator on the **** line up with the dimple in the housing.
Once the **** is lined up, a few taps with the rubber mallet seat the **** again. The first turn of the **** (counter-clockwise since you are already past the lock position) with take some wiggling to get the **** set into its track.
After I greased the ***** and re-assembled them, I worked them back and forth several times until the felt really smooth and buttery. I then re-installed my internal guts and popped the snap ring back in. And I was done!
Old 11-11-2014, 07:49 AM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
Snowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputation
Nice write up!
When I was having trouble with the hubs on my 6.0 I just drilled a tiny hole in the corner of the turn **** and injected some oil threw the hole into the unit and worked it back and forth all while on the truck. Worked great!
Old 11-11-2014, 07:56 AM
wizkid00104
Originally Posted by Snowseeker View Post
Nice write up!
Thanks! That's something I wouldn't have thought of for quite a while. I will keep that idea in mind
Old 11-12-2014, 02:55 PM
EXv10
EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
Lots of people can benefit from this. I have been waiting for this thread for a long time.
Old 11-12-2014, 03:05 PM
wizkid00104
Thanks! It was the best accident I've had yet
Old 11-19-2014, 09:37 PM
1975StroppeBaja's Avatar
1975StroppeBaja
1975StroppeBaja is online now
1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold
Nice job! Thanks for the pics & info. Reps to you!!!
Old 11-19-2014, 09:47 PM
wizkid00104
Thanks Jason!
Please feel free to add this information to your ESOF Hub Service article. Without your article, I wouldn't have discovered that the **** comes off in the first place.
Old 11-20-2014, 01:20 PM
EXv10
EXv10 is offline
A rare and highly informative thread., and it bolsters my idea of keeping your stock hubs.
Old 03-05-2015, 02:08 PM
wizkid00104
Just a quick update... throughout the sub zero winter with all of the lovely road salt and brine, the hubs still turn as easy as when I greased them. Zero issues. Definitely worth the time I put into it.
Old 03-05-2015, 08:24 PM
senix's Avatar
senix
senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Keep in mind that one should manually turn the hubs to keep them working properly.
Old 10-19-2015, 10:09 AM
Bently_Coop's Avatar
Bently_Coop
Bently_Coop is online now
Bently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputation
Awesome write up.
wizkid00104
1103
07-02-2018 08:08 PM
truckdog62563
38
06-11-2018 08:13 PM
truckdog62563
Large Truck
08-19-2017 08:04 PM
truckdog62563
04-10-2017 06:55 AM
truckdog62563
96
02-04-2017 03:39 PM
Quick Reply: How to Service the Selector Knob on 99-04 Hubs
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
