5.0 Head gaskets
Old May 23, 2011 | 03:23 PM
robramsey's Avatar
robramsey
5.0 Head gaskets
I would like to know if on small block if head gasket put in backwards can you still see the flow in the radiator?
Rob
Old May 23, 2011 | 06:36 PM
xlt4wd90's Avatar
xlt4wd90
Yes, you will probably see flow in the radiator; the bulk of the coolant will still flow through. The correct orientation of the gaskets will place their steam transfer hole over the correct spot on the block. If you blocked those holes, you can cause overheating problems.
bruno2
Jun 8, 2012 11:56 AM
jake47
1983 - 2012 Ranger & B-Series
Dec 1, 2006 06:48 AM
mgazak
1997 - 2003 F150
Oct 31, 2002 09:15 PM
mtflat
Aug 21, 2002 03:11 PM
bigsnag
Aug 9, 2000 07:44 PM
