Trailer Light Harness
Old May 23, 2011 | 02:00 PM
Justin's Green Truck's Avatar
Hi,
I have a 1977 F-150 Custom with 351m and 4x4.
I bought a new trailer this weekend to pull my boat and it has the 5 pin trailer electrical harness. Now the truck only has a 4 pin. The extra one on the trailer, from what i understand is to allow the trailer to be reversed since it has disk trailer brakes. I imagine there is an electrical solenoid on the trailer that keeps the brakes from applying when you go to back up.
Now my question is: What is needed to make this work with my truck? Is there an adapter for the pigtail or do I need to connect that extra wire on the trailer to my reverse lights on the truck somehow? Thanks for any help.
Old May 23, 2011 | 02:21 PM
Looks like I need to wire in a 5 pin harness to the truck and connect the extra one to the reverse lights. Is this correct?
Old May 23, 2011 | 03:38 PM
78 PEB's Avatar
78 PEB
Never seen anything like youre describing................ Normally, trailer wiring consists of the following circuits:
Left turn / Brake light
Right turn / Brake light
Tail lights
Trailer brake feed
Ground
B + Hot wire for interior lights
Possibly a switched hot lead for charging a battery on the trailer/ or for reverse lights on the trailer.
A lot of times noone runs the ground wire, thinking it will ground thru the ball, but I highly reccomend utilizing the ground. It prevents a lot of problems
Old May 23, 2011 | 11:35 PM
EJ AZ's Avatar
EJ AZ
You are absoultely right. You need to get a 5 flat plug for the truck hook up all the colors just like your current 4 flat and run the extra wire to the reverse. The nice thing is that your other trailers that use the 4 flat will usually plug right in to the 5.
Old May 24, 2011 | 10:24 AM
Thanks for the help. I got it fixed last night. Theres an adapter that they sell at parts stores for this. You just plug it in and run the extra wire to your reverse light circuit on the vehicle.
inboardfan
All Things Towing
Nov 19, 2015 09:16 PM
Tifford
Electrical Systems/Wiring
Sep 14, 2013 05:54 PM
CobraGT40
Aug 26, 2013 09:17 AM
johnEboy
Apr 20, 2008 12:34 PM
RussellF
All Things Towing
22
Apr 1, 2007 10:23 PM
