Where to buy missing block plug?
Old May 23, 2011 | 01:00 AM
lvin4jc's Avatar
lvin4jc
I'm missing the plug shown in the pic attached. When I ad water to the radiator it spills out this hole in the rear driver's side of the block. What is it called and where can I get a new one?
- Joe -
Old May 23, 2011 | 08:59 AM
C G B's Avatar
C G B
Freeze plug or a NPT plug?
Any auto parts store should have one.
Old May 23, 2011 | 09:10 AM
66f-100's Avatar
66f-100
You should be able to get one at any auto parts store or hardware store as mentioned above. There should be one just like it on the other side. Take that one out and take it with you so you can be sure that you get the correct drain plug.
Old May 23, 2011 | 12:13 PM
lvin4jc's Avatar
lvin4jc
I was thinking freeze plug, maybe that's why it was missing.
Good tip about the other side, that will save me some time/hassle.
Old May 23, 2011 | 06:26 PM
66f-100's Avatar
66f-100
The freeze plugs are the larger ones and are tapped in. That looks like a block drain to me. There should be threads in the hole if you look at it carefully.
Old May 23, 2011 | 07:40 PM
lvin4jc's Avatar
lvin4jc
I haven't had the chance, it's been covered by almost a full inch of grease. I spent the afternoon degreasing it and now you can see some cast iron down there. I'll check but i'm sure you're right.
Old May 23, 2011 | 08:07 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
It's not a freeze plug, nor is it a 1/4" pipe thread fitting...though you could use one.
As original: 8A-8115-A (replaced 8A-8115) .. Engine Block Drain ****-1/4" pipe thread.
Applications: A gazillion 1949/90's FoMoCo Passenger Cars/Trucks I-6 & V8.
Prolly available at any autoparts store.
Old May 23, 2011 | 08:13 PM
ford390gashog's Avatar
ford390gashog
Its 1/4 NPT, like bill said it should have had a drain **** in it but I have just not had good luck with those so I replace it with an allen head drain plug for easy future removal.
Old May 23, 2011 | 11:35 PM
lvin4jc's Avatar
lvin4jc
Thanks so much for the replies guys, I felt like it was a stupid question when I posted but i'm glad I asked.
Goldenvoice
Nov 14, 2012 01:15 PM
IntheTrees
Aug 4, 2009 07:19 AM
glruff
Pennsylvania Chapter
29
Apr 15, 2008 02:09 PM
Ironwoodsmith
May 14, 2007 08:45 AM
Okiedokie
Apr 13, 2005 01:57 PM
