Door handle, circle spring-HELP!
Old May 22, 2011 | 06:39 PM
65F100390's Avatar
65F100390
Exclamation Door handle, circle spring-HELP!
I went to get in my 65 F100 and the door wouldnt close. After looking at it, it would appear that the small circular tension spring inside the door has broke. Any ideas on how or where to get one? THANKS!
Old May 23, 2011 | 09:13 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If this spring is located on the door latch, it was only furnished with the latch.
If it's located on the door lock remote control (the handle attaches to it), it was only furnished with it.
If it's located somewhere else, I haven't a clue, cuz I don't think it's located anywhere else. I'm betting it's the curly-cue spring on the remote control.
Old Apr 16, 2012 | 04:08 PM
65F100390's Avatar
65F100390
Yeah, I got the part I need, still need to put it in.
Old Apr 16, 2012 | 04:57 PM
KJHouston's Avatar
KJHouston
On this vein, Im having trouble getting the driver door on my 65 to latch all the way. It clocks once and holds, but doesn't make the second click to close all the way. Tried trimming the loose weather stripping to no avail. Is this common?
Old Apr 16, 2012 | 05:24 PM
65F100390's Avatar
65F100390
I would look at alignment maybe? I have never had this problem with mine.
Old Apr 16, 2012 | 05:28 PM
KJHouston's Avatar
KJHouston
It lines up alon the path it travels, but doesn't seem to make it in far enough to clear the second ridge on the receiver. I tried force, and don't see anything binding or indication the door is misalligned.
Old Apr 16, 2012 | 06:15 PM
65F100390's Avatar
65F100390
It may need a new reciever part. I think LMC truck has them pretty cheap. My guess is that it is worn down some, maybe?
Old Apr 17, 2012 | 03:47 AM
NumberDummy
C1TB-8121818-B .. Door Lock Remote Control Assy-has splines that the inside door handle fits onto, includes curly-Q spring / Right/Left is the same / Obsolete
Appllications: 1961/66 F100/1100 / 1963/69 N/NT/T500/1000 / 1967/69 F800/1000.
CARPENTER NOS OBSOLETE PARTS in Concord NC has THREE = 800-476-9653.
No Ford Dealer, no other obsolete parts vendor has any.
Dayotte27
Nov 26, 2013 04:57 PM
My9fam
Feb 22, 2013 01:42 PM
paulmdahle
Nov 21, 2008 02:32 PM
hoofangler
Jul 29, 2005 10:23 AM
lotsahair
Aug 22, 2000 09:13 PM
