6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Differential fluid change fill up
Old May 22, 2011 | 04:13 PM
chi6488's Avatar
chi6488
I am wanting to change the differential fluid due to the towing I do with a 11k lbs boat and 10k lbs travel trailer.
I noticed that the fill plug is half way up the plate towards the front of truck. The trans axle plate has bolts in the rear so I will have to pry the cover loose once loosening the bolts.
How do I fill the fluid full if the fill plug is only HALF way up the plate??
Maybe instructions how to do this procedure. I am sure dealer wants 2-300 bucks for the job.
THanks
Old May 22, 2011 | 08:18 PM
galaxie641's Avatar
galaxie641
You don't fill the diff clear full, it won't even fill all the way to the fill plug. The owners manual has the capacity listed under capacities and specifications.
Old May 22, 2011 | 08:19 PM
senix's Avatar
senix
No trans axle on this truck. Terminology is rear differential.
You take the cover off of the rear diff to do the job. To refill you use that hole for the plug. Just fill it according to the owners manual...or to the treads.
consult the manual for the type of fluid.
Also the cover does not have a gasket. So some silicon to get the seal is in order.
Old May 23, 2011 | 01:59 AM
ford390gashog's Avatar
ford390gashog
Honestly local ford dealer charges me about 65.00 a diff to do it. The price is decent so maybe look into it.
Old May 23, 2011 | 03:31 AM
zxwut?'s Avatar
zxwut?
Just use a hand pump that you can buy at any hardware or auto parts store, and fill it to the hole.
Old May 23, 2011 | 06:48 AM
chi6488's Avatar
chi6488
I'll check into the price. I haven't yet ruled it out but had not had a chance to call dealer. I still need to do the pcm recall anyways
Old May 24, 2011 | 09:28 AM
chi6488's Avatar
chi6488
Just checked with my local ford dealer where I bought the truck. Don't know is service adviser was wrong but she quoted $250 b/c it too synthetic fluid..
Think I will do it myself
TC-Countryboy
Mar 3, 2026 07:40 AM
tbugher62
Dec 17, 2013 02:33 PM
Ricache
24
Sep 15, 2009 02:08 PM
caseys
Feb 21, 2007 11:25 PM
DOUG5G
Aerostar
Feb 19, 2006 10:38 AM
