Aerostar Ford Aerostar
Differential fluid level and check
Old Feb 17, 2006 | 09:56 AM
DOUG5G's Avatar
DOUG5G
I think I my rear differential is leaking. I see oil on the drivers side rear axel and around the differential.
If I open the fill plug how full should it be?
Doug
93 3.0 138K
Old Feb 17, 2006 | 12:06 PM
copper_90680's Avatar
copper_90680
Assuming your van is sitting on a level surface, the fluid should be right below your fill hole. When you fill it, just fill until fluid starts seepng out the bottom edge of the fill hole, then you're done.
Old Feb 17, 2006 | 07:58 PM
DOUG5G's Avatar
DOUG5G
What type of fluid should I use?
Old Feb 17, 2006 | 09:26 PM
savagefan's Avatar
savagefan
Keep it all the same, if you don't know what's in there after changing the axle seal and possibly axle and bearing fill 'er up with synthetic 75w140.
Old Feb 17, 2006 | 11:21 PM
96_4wdr's Avatar
96_4wdr
dump and change diff lube...good time to examine the interior and lube for any cuttings and pinion/ring match...use only 75w90 per Ford specs...higher viscosity will lower your fuel mileage...synthetic not needed unless you live in cold -20d F climate or plus 110d F or you do lots of heavy hauling or towing
Old Feb 17, 2006 | 11:30 PM
savagefan's Avatar
savagefan
Dude, he has leaks, address those first before arguing oil type. Besides why not be ready for extreme service for the few extra dollars outlay?
Old Feb 17, 2006 | 11:43 PM
96_4wdr's Avatar
96_4wdr
Doug has a question about fluid to use, I answered....copper had already covered Doug's question about diff lube level
is there anything further?
Old Feb 18, 2006 | 09:09 AM
savagefan's Avatar
savagefan
Doug, pull the driver's side brake drum and check for oil contamination on your shoes. If the leak in there is bad it should be repaired first. Also make sure the vent isn't plugged.
Old Feb 18, 2006 | 11:48 AM
DOUG5G's Avatar
DOUG5G
The leak is very slight and has not gotten close to the brakes but, thanks for the info. I opened the plug when it is about 7 Degree F outside and the oil is as thick as syrup. But is was also very close to the lip so I don't need to add any right now.
I had that gasket replaced when the van was under warrenty.
I would replace it right now but I am not at home and don't have any place to work on it. It is way to cold outside to do anything but the basics.
Where is the vent?
Old Feb 18, 2006 | 06:52 PM
b2trausch's Avatar
b2trausch
My rear diff started leaking also. The problem was due to a cracked vent hose. Look for the vent hose about mid way down the axle (top) on the drivers side. It's possible that the hose has broken off also.
Old Feb 19, 2006 | 10:38 AM
copper_90680
Doug:
You might want to read this.
https://www.ford-trucks.com/forums/s...0&page=1&pp=12
Muppy1840
Dec 28, 2016 11:59 AM
Tom Callan
Dec 6, 2016 01:25 PM
Caldwell F150
Oct 30, 2016 10:37 AM
66with352
1997 - 2003 F150
Oct 28, 2016 09:54 AM
daveplot
Jun 27, 2011 12:05 PM
