Change front diff fluid...Yikes!
Old Feb 21, 2007 | 08:58 PM
caseys's Avatar
caseys
Red face Change front diff fluid...Yikes!
xxxxxxxxxx
Old Feb 21, 2007 | 09:35 PM
mikeinri's Avatar
mikeinri
If you're just doing this for PM, and are not having issues (weird noises, leaking gasket, etc.) sucking out the fluid is a much easier way to go.
The main benefits to pulling the cover is that you can replace the gasket (if leaking) and you can inspect the gears for damage.
If it's not leaking and not noisy, I would just use suction.
Mike
Old Feb 21, 2007 | 10:25 PM
Rangerman Stan's Avatar
Rangerman Stan
The other thing you could do is jack up the front of the truck by putting the jack on the frame. Then as the truck goes higher it will give more room for the bolts and cover to come off. Just remember to support the frame with jack stands.
Old Feb 21, 2007 | 11:25 PM
caseys's Avatar
caseys
xxxxxxxxxx
josh1095
Oct 26, 2018 10:17 AM
hharris8
1978 - 1996 Big Bronco
Sep 5, 2016 09:49 AM
Thumper47
1983 - 2012 Ranger & B-Series
Nov 8, 2011 11:27 PM
Urban_Prisoner
Jan 17, 2011 08:56 PM
mikren
1997 - 2003 F150
Sep 15, 2009 08:09 AM
