Door Adjustment
Old May 22, 2011 | 03:13 PM
mr_ranger-79's Avatar
mr_ranger-79
Door Adjustment
Does anyone here have any experience on adjusting the doors on these trucks? I had to replace the door hinges awhile back on the passenger side and have been playing hell getting the door to open/close correctly. What is the recommended way of doing it? Mounting hinges to truck first and then adjusting, or to door first? Or does it matter? Any tips would be greatly appreciated, thanks in advance.
Old May 22, 2011 | 04:19 PM
triplecreek's Avatar
triplecreek
I would bolt the hinge to the cab first and go from there. Ir you are doing it by yourself put a floorjack under the door to help raise and lower it.
Old May 22, 2011 | 06:34 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Is this with new weatherstripping as well? It's a pain with new rubber versus old broken in stripping.
Basically align the door to match the a-pillar and fender. Watching your gaps all the way around.
Then move the striker either in or out to finalize the door closing.
If the door is hard to open and close one if the hinges might be binding from Bering crooked in relation to the other hinge.
Aligning the doors is slightly better than trying to align the hood so hang in there.
If you're dealing with new rubber the door will likely not close properly until the seal settles in.
Josh
CountryBumkin
Jul 25, 2017 02:22 PM
Outlaw56
13
Oct 24, 2016 08:59 PM
abe
Oct 17, 2016 01:01 PM
chaines
Oct 19, 2013 03:36 AM
stallion3599
Oct 7, 2012 10:22 AM
