03 no start help please
Old May 12, 2014 | 08:59 PM
chev69ss's Avatar
chev69ss
Here I go again just made a run to Pennsylvania for a good deed and now the 350 is out of commission.trucks been runnin great all of a sudden cranks like crazy but not tryin to fire.so I've got a little info
Codes2285
P2291
Key on eng off:icp volts .14
Ipr. 14.4
Icp. 0
Cranking: Icp volts. .43
Ipr. 77.6
Icp. 235
Also unplugged icp and cranked with no difference.strong fast crank,great battery's.and awesome eds ficm put in 5/13
This is all the info I was able to get so far before I had to quit for a few days cause of my health issues.i think I'm scaring myself with hpop thoughts and maybe need more info first but hoping one of u pros might tell me I'm just being too nervous too fast so please give me your thoughts good or bad..thanks everyone really appreciate you all.
Old May 12, 2014 | 09:06 PM
KDAVID1's Avatar
KDAVID1
You got a leak. Icp should be 500min. I think
Sorry im new at this diagnostic stuff
Old May 12, 2014 | 10:04 PM
78fordman's Avatar
78fordman
Pull the ipr and check the screen. Even if the screen is good remove it and take a 1/4" screwdriver and press in on the cone shaped piece under the screen. Spray some carb cleaner and blow out with while pressing in. The piece has a spring behind it so it should close back up. Reassemble and see what you have. The 03 and early 04 trucks have alot better hpo plumbing not very prone to leaks.
Sent from my leash using IB AutoGroup
Old May 12, 2014 | 10:06 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Been a rash of failed early 6.0 HPOP's lately...
Josh
PS Sorry Benny, that's a dig at ya!
Old May 12, 2014 | 10:08 PM
78fordman's Avatar
78fordman
Don't jinx me. Mine has a reman in it, the only reason I know this is because it is stamped on it. Ticking bomb waiting to go.
Old May 12, 2014 | 10:17 PM
Bullitt390's Avatar
Bullitt390
Nah... Usually early 6.0 HPOPs are bad right out of the box. If the engine starts you should be good to go for a while.
Josh
Old May 13, 2014 | 09:14 PM
chev69ss's Avatar
chev69ss
Hey thanks for the responses taking a little time to recover physically then I'll get right in and try the ipr cleaning.i wasn't sure if that could cause the low oil pressure I was seeing on cranking,but I'm sure glad there's at least one more possibility.i'lll post results as soon as possible.by the way this hpop was new from ford installed january of 2012 that's why I'm hoping its something else!thanks again guy's...
Old Jun 2, 2014 | 10:21 PM
chev69ss's Avatar
chev69ss
Ok so sorry for the delay been getting slaughtered with health probs.so I was finally able to pull the ipr valve what I found was no apparent clogging but the screen was blown out. So I removed the screen and as a test I applied 12v to terminals and valve is definitely actuating so it would appear to me that its working.that being said,and the fact that I still got a no start when unplugging icp and trying to start I'm thinking hpop but if you guys could give me your opinions I would really appreciate the guidance.running my excursion for everything at a grand old 9to10 mpg is a killer...
Old Jun 3, 2014 | 12:04 PM
chev69ss's Avatar
chev69ss
Also important to mention is just last yr head studs and gaskets were done along with the hpo tubes that Run thru the heads.not that this would rule out a hpo leak from an internal source but it just lessens the odds i.m.h.o. Even though my hpop is so recent and was a new not rebuilt unit from ford I'm stressing that its the culprit.again if some of u well schooled in the diagnostics could give me your opinions I would appreciate it
Timberhunter
Aug 6, 2007 12:46 PM
eric777
Aug 3, 2006 11:09 AM
MRDEW
Dec 4, 2003 03:15 PM
PRDATOR
Nov 11, 2003 02:01 PM
birdman127
Sep 6, 2003 10:36 AM
