Cluster
Old May 21, 2011 | 09:20 PM
mooner's Avatar
mooner
Cluster
Hi all,
I have a 05 E350 with 6.0 Diesel, the question I have is if I replace the instrument cluster with one from a junk yard will I have to do any other things to vehicle other than swap them. Before ya ask, old cluster has a short in the circuit board and unless I keep pressing on the odometer reset button all guages go out, including tach and speedo. Than truck goes into limp mode and radio turns off interior light comes on all on its own. I have slid a piece of plastic into the cluster spacing circuit board away from contacts in that area and everything works (sort of) no speedo and tach is out by 1000 rpm.
Thanks
Old May 22, 2011 | 01:00 AM
zhilton's Avatar
zhilton
No, should be able to "plug & play". All the odometer information is on the PCM and not in the cluster.
Rogue_Wulff
'80-'86 HOWTO's
19
Jan 21, 2025 10:13 PM
Bluethunder3320
Apr 6, 2014 08:12 AM
Rogue_Wulff
16
Mar 19, 2012 08:38 AM
desperado_18_2000
Oct 31, 2005 12:59 PM
bubbaf250
Apr 30, 2002 12:09 AM
