HPOP dis-assembly
Old May 21, 2011 | 05:46 PM
whitefordexplorer's Avatar
whitefordexplorer
Question HPOP dis-assembly
anyone know where i can find a set of instructions to take apart the HPOP, i got a set of o-rings from Bob at Dieselorings.com< and i cant seem to figure out how to get the bacing plate thats held in by the snap ring out....... any help would be awesome... thanks!
Old May 21, 2011 | 06:46 PM
whitefordexplorer
Um babe.... The explorer is mine. The piece of **** car Dodge Neon is yours... Luckily its only temporary until your Ranger is running. Love you~ Your wife
Old May 21, 2011 | 07:00 PM
hammer65's Avatar
hammer65
Here is a link to Rubberducks write up.. Don't know if it addresses your problem or not. Jim
https://www.ford-trucks.com/forums/5...-part-1-a.html
Old May 21, 2011 | 07:45 PM
F350-6's Avatar
F350-6
Is it actually leaking from there? It almost never leaks from that o-ring.
Are you working on it with the HPOP still in the truck or out on a bench? Maybe you'll get lucky with a good magnet pulling the back plate off. If the o-ring is leaking then there should be a bad spot on the oring. Tap the edge of the plate with something to see if you can knock it crooked enough to pull the plate off.
Old May 21, 2011 | 09:19 PM
DieselOrings's Avatar
DieselOrings
SPONSOR
The only way I have been able to get it out is by using compressed air into one of ports. Oil surface tension holds it on like vise grips ... LOL
The problem is that you will need a very large C-clamp to be able to slightly compress the new o-ring enough to re-seat the c-clip.
__________________
Specializing in Viton® o-rings and leak repair kits for the 7.3L and 6.0L diesels
(970) 368-4455 aka guzzle
guzzle's Mods & Maintenance website
Old May 21, 2011 | 11:35 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
If it isn't leaking I WOULD NOT remove it.
Old May 22, 2011 | 08:32 PM
whitefordexplorer
well, i opted not to remove it, didnt seem to be leaking when i took the HPOP out of the truck, so i just replaced every other seal on it, now i got it all back together and i have crank but no start, i did not replace the IPR, im getting plenty of fuel (bowl is full, and when i checked to see if there was anything in there, it squirted out...) i filled the HPOP reservior and now i cant get to that plug to see if i need to add more or not.. im gonna try to take the IPR senso wires off and see if it works that way.... any other ideas would help a bunch, im tired of messin with this truck....
Old May 22, 2011 | 09:16 PM
bulla's Avatar
bulla
Why cant you get to the plug to check the res.? It right on top. Also the ipr isn't like the icp, it has to be plugged in to run. Maybe try unplugging the icp, I think I read on another current post that this might unstick a stuck ipr! By the way sometimes it just takes a lil time to get it fired after having the hpo system opened! This is when the ae comes in handy!!
Old May 22, 2011 | 11:58 PM
Bonanza35's Avatar
Bonanza35
The plugs right on top. Pull it off and add oil there. If its full and all sensers are pluged in it should start. Had know problem when I changed mine. I just left a fuel line loose and it blow off, what a mess. I shouldn't of had lunch before starting.
Old Jul 24, 2011 | 08:28 PM
whitefordexplorer
well, the truck has been running and NOT leaking a thing for the lasst month now. i just had to add more oil to the HPOP and she fired up! thanks for the help and sorry for the long delay on response, i dont get access to a computer all that often.
Cobra Highboy
15
Sep 5, 2013 01:27 PM
mark460
Oct 6, 2011 09:24 AM
88f1504x4
May 2, 2011 08:18 PM
FuzzieLogik
104
Jan 25, 2010 01:01 AM
