No start prob,
Old May 21, 2011 | 12:25 PM
j540john's Avatar
j540john
No start prob,
Ok it starts on starting fluid,but as soon as you stop spraying it it shuts off, put in a different FICM,oh and I did the fix on the stock one and it has 48V, oil comes out of sensor hole on pass, side valve cover,and putting my finger i can't hold pis back, fuel filter bowl fills up, put new Orings and screen on HP solenoid behind turbo. have a granatelli programer to check codes. I get all the inj codes p0261,p0264,p0282,etc. and p1102, p2285, p2290,p2617.
Any idea's. besides a match and a can of gas.
Old May 21, 2011 | 02:06 PM
Dieselpop's Avatar
Dieselpop
If you keep useing starting fluid you will not need a match and a can of gas it will blow on it's own, how good are your batteries still may be FICM because the codes are for low injectors and CP open others may have a better idea
pop
Old May 21, 2011 | 10:32 PM
j540john's Avatar
j540john
Yeah yer right. Thats why you turn it over before you spray it or the glow plugs will ignite it. And boom.
fordguy2236
Jan 4, 2015 05:06 PM
gesb123
Oct 29, 2014 08:46 AM
Restlesswildman
Sep 23, 2014 07:23 PM
HSaavedra
Mar 30, 2014 11:05 AM
NovaNewfie
1997 - 2003 F150
Mar 9, 2014 10:04 AM
