How to avoid bending push rods??
Old May 20, 2011 | 08:07 PM
john11139's Avatar
john11139
I have read here that a few fellows have had problems bending their push rods after replacing their head gaskets. I have my engine out and replacing a piston and two valves due to a turbo going bad. I dont want to bend any push rods when I put it back together. Seems like I saw a bullitan that said something about having the notch on your viberation damper at 6 oclock or catstrophic failure could occour. I dont see a notch on my viberation damper. I dont see how you could not get the push rods in wrong. Any help appreciated. What are they refering to as catstrophic failure?
Old May 21, 2011 | 07:23 AM
npccpartsman's Avatar
npccpartsman
Check out this thread: https://www.ford-trucks.com/forums/1...g-back-on.html
It's the best/simplest explanation of the procedure. Remember to roll the motor over several times BY HAND before the final head bolt torque.
timmosazz64
Nov 28, 2016 10:13 AM
doug42190
Jun 10, 2016 10:25 AM
Blake Phipps
Aug 24, 2013 11:29 AM
FordF150Fixer
4 Cylinder Engines
Jul 24, 2004 06:58 PM
Cole
Jul 13, 2004 11:44 PM
