Liftkit
Old May 17, 2011 | 02:56 PM
BIRDMANN79's Avatar
BIRDMANN79
Liftkit
Looking to raise my truck up slightly ....I know that the front needs leveling however what would you all suggest ? Im just looking for opinions and such .....its an 07 f250 2wd ..I couldnt attach a pic but same truck is in my avatar ...
Also looking into a compressor/tank and horns ...any suggestions there ?
Old May 17, 2011 | 08:39 PM
crivaro's Avatar
crivaro
Just leveling it makes it look 100% better! They make leveling spacers or leveling coils to raise er up. Not a really hard or expensive project and the end result is good!
Old May 17, 2011 | 09:07 PM
2006powerstroke90's Avatar
2006powerstroke90
I know you will be able to find a leveling kit for your truck.
When I had my 2wd cummins I could not find a lift kit for it anywhere.
I'm sure it would be the same scenario for a 2wd powerstroke.
A leveling kit will improve it by much.
Old May 18, 2011 | 04:57 AM
BIRDMANN79's Avatar
BIRDMANN79
Thanks guys !
Old May 21, 2011 | 08:08 AM
crivaro's Avatar
crivaro
Just looked online, Fabtech sells lifts for 2wd Superduty's if you really wanted to go higher than just a leveling kit.
Old May 21, 2011 | 08:43 AM
rotun's Avatar
rotun
Reads ***** rules!
Here's a link to an onboard compressor discussion....................
https://www.ford-trucks.com/forums/1...board-air.html
Old May 21, 2011 | 09:20 AM
cheezit's Avatar
cheezit
2" front 1.5" rear. may need to drop the carrier bearing a little to stop the vibration on take off.
