dash gauge bulbs
Old May 21, 2011 | 08:58 AM
xc4jokestomper's Avatar
xc4jokestomper
Everyone look at the link 86f150 posted. He has a very nice writeup on that site and is the one that ill be using
Old May 21, 2011 | 12:07 PM
BIGskinny's Avatar
BIGskinny
he made it look so easy lol..mine dont wana come out like that
Old May 21, 2011 | 08:28 PM
xc4jokestomper
Welll im stuck too. I cant get mine pull out either. Im guessing its my speedo cable as well because i already unplugfed everything on mine. How do you get it unplugged?
Old May 21, 2011 | 10:36 PM
L. Ward's Avatar
L. Ward
You have to unclip it from the backside (sorry I don't remember the exact way it unclips) If I remember correctly, it should pull forward enough for you to reach back and feel how it unclips though. If it wont pull forward enough, most likely the cable is hanging up. All I can suggest is fishing around behind/under the dash and see if you can get it loosened up some.
Old May 22, 2011 | 07:05 AM
xc4jokestomper
Alright ill yry that. It looks like it goes up into the bottom of the gauge though, not the back
Old May 22, 2011 | 07:41 AM
BIGskinny's Avatar
BIGskinny
besure to throw up some pics on here when u get the swap done, im really curious to see how it looks.
Old May 22, 2011 | 07:55 AM
xc4jokestomper
I hope you have small hands is all i can say because theirnisnt much play room
Old May 22, 2011 | 08:35 AM
BIGskinny's Avatar
BIGskinny
im 6ft 305lbs hands aint small lol...ill have one of my buddys thats got small hands do it for me when i go to pull it off again.
Old May 22, 2011 | 11:29 AM
xc4jokestomper
I feel your pain bub. Im 6'2 210lbs. Its not too bad but another suggestion of mine would be to use the kind of bulbs posted in 86's writeup, the good kind! Mine are cheap and i figure ill be doing this again in the next 6 monthes. Im having trouble with the ones im using as well. Theretoo long and stick out to far and is hitting something. I have pics ill post later of the size differences.
Old May 22, 2011 | 01:21 PM
BIGskinny's Avatar
BIGskinny
hmm will they work? or they to long period? yeah id like to see some pics when u get the chance no rush, im wantin to get away from the old green and do a diff color.
Old May 22, 2011 | 08:30 PM
xc4jokestomper
they work fine for the blinkers (look BA), and three of the illumination lights on the gauges. the other two i had problems with. ill get some pics up as soon as i can. i got school tomorrow and work right after that.
i wouldnt try and discount any of this. trust me its going to be a job you arent going to want to do again. plus the bulbs i have you have to get in there just right or they wont stay lit up. i went over a bump and one of my ac panel ligths went out..
also when trying to get it unplugged i must have had my gauges laying too flat because the only 2 of my 6 gauges are working now.. tach and speedo only. so im going to start a thread about that and check out my options for that.
Old May 25, 2011 | 03:47 PM
xc4jokestomper
alright i fixed my gauge problem. the plug wasnt in all the way! ill have to wait and see if the lights are working. probably not because the bulb i used was too big. ill have to order some like in 86's write up sometime.
heres some pics. the bulb on the left is the bulb i ordered the first time that wasnt bright enough and ended up in my license plate lights. the bulb on the right is the one i ordered this time and was too long for two of the holes. the housing wouldnt go back up into it far enough to turn it to lock it in.
and heres some of the goodside of the gauges where they actually lit up.
Old May 25, 2011 | 04:13 PM
  #28
BIGskinny's Avatar
BIGskinny
hmm it dont look bad it looks better then the ol stock green..hmm thats no good. ill deff keep in mine to not tryin do this the cheapest way..thanks for the pics and advance
Old May 25, 2011 | 04:19 PM
  #29
xc4jokestomper
Pics dont really do it justice. Its from my iphone. The numbers and stuff are like a blueish green aqua but the needle is like a neon blue
Old May 25, 2011 | 04:27 PM
  #30
BIGskinny's Avatar
BIGskinny
so over all id say its better then the way the stock lights were?
