How do i bypass the smog pump from a 89 f150 4wd with 302? Do i just get a shorter belt and pull all of it out? To my knowledge its just dead weight. The tube from the exhaust has been sealed off. I'm assuming that its dead weight b/c of this. Is there something I'm missing? The reason why I'm Thinking of taking it off is b/c its squeaking (chirping sound) when the motor decelerates. Does anyone know the size of the belt i would need? Is this even a good idea, and no i don't have to worry about emmisions testing.
A new Thermactor will set you back around $30, which isn't much. You won't gain anything by bypassing it and will probably lose 1-2 mpg on the proccess, as i did (i eleminated mine because i couldn't find a new one in my country).
if you no longer have a converter then its just an extra pulley. i cant imagine that you would loose mileage but you do have to have a bit of back pressure.
Ok i checked some things with a stethescope, smog pump is ok, crankshaft, power steering, alternato and compressor are all ok. Could it be the water pump? While it was running i made the tensioner tighten up ( not the smartest thing) butim running out of ideas!!!! Anyone have any suggestions?
Well, heres the update. I took the belt off and cranked it. Still squealing, so i climbed under it and noticed the starter was loose, tighted it and it fixed the squealing!!!
