My trans. is shot and needs to be replaced. Does anyone know what manual trans. they put in that year and if they are interchangeable. My truck has the 5.0, 4x4, and I do know its not the "granny low" tranny if that helps any. Also, how can I tell what tranny it has, Ive gottan under and looked but was unable to see any indentifing marks or numbers.
Thx
RP
I have the same setup, the transmission should be Mazda-type M5OD, also called M5R2. There is a tag on the driver's side door pillar that shows what trans it came with...under Trans mine just says 'M' I guess for manual.
Any year of those tranny will bolt right up, as long as they come out of another 4x4 truck, and are off a small block engine. (4.9L inline 6, 5.0L V8 and 5.8L V8.)
I have called a couple of salvage yards and I was told two 5 speed manual trans were used, one was the mazda and another call ZF. I was told the M on the inside of the driver side door means its the Mazda trans.
