Sharing a picture
Old May 21, 2011 | 06:19 AM
2006powerstroke90's Avatar
2006powerstroke90
Sharing a picture
This is from the turbo I pulled out of a truck from the company I work for...
I wonder what would have caused this.
Old May 21, 2011 | 06:50 AM
Chief-e9's Avatar
Chief-e9
Could one vane have failed and a piece broke off; then that piece hit the other vanes causing them to break, also? Is it possible a "foreign object" entered into the area resulting in this damage? If yes, I imagine you would have found it. It will be interesting to see what you determine. Roy
Old May 21, 2011 | 09:29 AM
cheezit's Avatar
cheezit
if you look at the vgt fins you will the damage will match the size and shape of the fins. turbo got stuck and unison ring overtravled.
Old May 21, 2011 | 09:35 AM
High Binder's Avatar
High Binder
When I took apart my turbo to clean it, I found that the unison ring would allow the VGT veins to come into contact with the fins right where you're damage is, which like Cheezit said may be your culprit.
Old May 21, 2011 | 10:07 AM
smokersteve's Avatar
smokersteve
That seems like a very stupid design....
Is there a way to modify the turbo so that it will not do this?
Old May 21, 2011 | 10:08 AM
cheezit's Avatar
cheezit
not a common issue
Old May 21, 2011 | 01:54 PM
2006powerstroke90
Old May 21, 2011 | 02:46 PM
High Binder
Yeah it's a very stupid design. I would expect to get fired for such a thing however I bet the reason it is like these is because this ring/vein/ect parts can fit into many of their models of turbos (saves money). You could modify the slot in the ring to disallow that interference it wouldn't take but a mm or so in the slot itself but you'd have to weld the slot and then mill it to spec. If I had one in hand I could do run the numbers and figure it out for you if you really want to do it. I doubt it would trip any codes or cause a problem with the VGT sensor because the sensor isn't going to (under normal conditions) force the veins into an interference condition. In short, if everything is working right you shouldn't need to mod the ring but if yours had been modded, it prob would have saved your company a $grand$.
2006powerstroke90
Sep 25, 2014 05:07 PM
2006powerstroke90
Sep 10, 2012 11:42 AM
2006powerstroke90
Dec 21, 2011 05:54 PM
2006powerstroke90
Jul 31, 2011 07:49 PM
2006powerstroke90
Jun 24, 2011 01:55 PM
