73 Super Camper Special
I recently inherited a '73 Ranger F-350 1 Ton Camper Special. It's actually a family airloom of which I've been given the honor to restore. I'm a bit of a car guy though my knowledge with V8s/domestics is minimal. The truck has quite a bit of things that needs to be addressed, most predominately the engine. I figure if I can find more information about the truck and the <a href="http://motorhaven.autoanything.com/"><a href="http://motorhaven.autoanything.com/">390 </a></a>I can make certain that I restore the truck properly.
I've done plenty of searches before posting, and could not find some information I've been looking for. Here's a few starter questions:
- Engine Specifications - HP & Torque Ratings?
- Engine, Chassis, & Tranny Designations/Codes
- Platform Compatibility (2wd to 4wd possibilities)
I'm planning on taking the truck to a shop to have the engine checked out. Hopefully if the block is still good, I'll just have it fixed. If not, I've been tossing around options such as swapping in the 460ci w/ a 4-speed auto (if avail) if the block is shot.
If anyone could point me into the right direction for information, I'd greatly appreciate it. Sorry for the length.
Regards,
You've got an "FE" motor. These motors are revered by most ford owners. The historical <a href="http://motorhaven.autoanything.com/">428 </a>is from the same block. A direct substitution would be a 360, 390, 428. The <a href="http://motorhaven.autoanything.com/">460 </a>is another family of motor and will cause you additional work to substitute.
What is wrong with your motor? Is it blown? Or does it run? Does it turn over or is it siezed? This will make a big difference if your going to "have it fixed".
In summary, the "FE" is a classic. There are many aftermarket parts available.
KingFisher
Try it there should be at least 5 threads with info.
Also, Please read this:
https://www.ford-trucks.com/forums/s...hreadid=102632
Infin,
You've got an "FE" motor. These motors are revered by most ford owners. The historical <a href="http://motorhaven.autoanything.com/"><a href="http://motorhaven.autoanything.com/">428 </a></a>is from the same block. A direct substitution would be a 360, 390, 428. The <a href="http://motorhaven.autoanything.com/"><a href="http://motorhaven.autoanything.com/">460 </a></a>is another family of motor and will cause you additional work to substitute.
The exhaust collectors are shot along with the mufflers. One of the exhaust collectors has a crack in it, and possibly missing a stud.
There's a few other items, but small stuff that I can deal with later down the line.
KingFisher
Did the 390s ever come with 4x4?
Thanks again for the good information.
Regards,
Did you try typing the words " Super camper Special" when you did your search ?
I have read the "Descriptive Titles" post, and thought my original title was somewhat accurate. I will make an effort to label future titles better.
Thanks for the suggestions and tip.
Regards,
This is what I just found.
https://www.ford-trucks.com/forums/s...der=descending
This one too.
Btw, You don't need to use the Quote.
We both know who we are talking to.
332/352/360/390/406/410/427/<a href="http://motorhaven.autoanything.com/">428 </a>FE V8 Forum
