question about grounding
Old May 18, 2011 | 09:26 PM
trumsey07's Avatar
trumsey07
i have a 300 inline 6 1986 and was wondering does the battery ground wire have to run down to the frame first and ground then to the tranny bolt or can it run straight to the tranny bolt
Old May 18, 2011 | 09:44 PM
JimsRebel's Avatar
JimsRebel
https://www.ford-trucks.com/forums/1...t-of-help.html
Photos and info here.
Jim
Old May 18, 2011 | 10:02 PM
trumsey07's Avatar
trumsey07
just a quick thought but if you run the wire straight to the tranny bolt wont the current still be connected the frame because the tranny is bolted to cross member
Old May 18, 2011 | 10:03 PM
trumsey07's Avatar
trumsey07
another quick thought but wouldn the ground use the first connection to the frame instead of splitting and going to the tranny bolt too
Old May 18, 2011 | 11:08 PM
Galendor's Avatar
Galendor
Grounds use whatever and all connections available to them, they are just a pathway back to the negative terminal of the battery. So the more the better. It might still work fine only going to the transmission, but consider that Ford may have had an actual reason for grounding that cable both to the frame and the transmission.
Old May 19, 2011 | 11:16 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
The battery negative cable is supposed to go to one of the starter mounting bolt. 300-6. Not the transmission.
There is an additional frame grounding tang, midway on this cable.
The tranny mount, and engine mounts are rubber insulated, and they are also meant to flex slightly under torque, so it's not a good grounding point etc...
The cab needs a ground cable from the engine to the firewall as well. The cab mount bushings are also rubber insulated.
Old May 19, 2011 | 11:52 AM
RAY1986F150's Avatar
RAY1986F150
Thanks for brining this up, I have a question on 86' 302 EFI grounding. I just pulled and rebuilt the motor and trans. The only grounding I saw on the whole setup was a negative battery cable to the engine block and some grounding lugs coming from the wiring harness that bolt to the intake manifold bolts. There may have been something going from the battery to the chassis but I can't remember. Shouldn't there be more than that? Like a strap going from the block to the chassis, or a strap going to the transmission somehow? Sorry to hijack your thread trumsey.
Old May 19, 2011 | 12:34 PM
81-F-150-Explorer
Yes there is a grounding point to the frame, but it's different between a 300 and 302.
The V8's can actually ground through the mounting bolts on the engine mounts.
The 300 cannot do it that way satisfactorly, as they are designed different, naturally.
You can add a cable between the engine block and the frame to satisfy your grounding needs as an option.
Old May 19, 2011 | 03:33 PM
RAY1986F150
Good idea. I think i will just go get some straps and put one from transmission to frame, one from engine to body, and make sure there is a battery to body. Can't hurt to have too many grounding point can it?
Old May 19, 2011 | 06:23 PM
trumsey07's Avatar
trumsey07
ok cause i have neg from battery straight to the sorry starter bolt but have not had any probles with it
Rick_Fury
Apr 13, 2013 08:01 AM
Edogrips
16
Aug 26, 2012 10:57 AM
krazeyelf
Feb 24, 2011 04:30 PM
Baxdoc
Electrical Systems/Wiring
Mar 9, 2006 11:58 AM
k2vailkid
Aug 31, 2005 10:49 PM
