New project
This is my first post but I have read back several years. I have just purchased a project a $100 91 4.0 extended. Other than one small dent under the tail light, and some peal on the clear coat the body is is pretty good shape, and other than a little dirt and doggy hair smell the inside is in pretty good shape also.
There are a few little problems like the back latch not working (probably needs lube) and both front windows do not roll down, needs some window rubber replaced, and there is no third row seating.
The motor seems to run just fine, but the transmission has failed.
I was able to coax it to back up with reving and dumping in a couple of quarts of ATF, but nada on making it go forward so I think the trans is kaput.
I have narrowed down my options to either getting a used AT from the junk yard, or getting a used stick shift and the stuff needed to convert to a 5 speed like the clutch pedal brake pedal clutch master slave etc.
I have had good luck in the past with junk yard transmissions opting to go that way on my 94 Taurus @50,000mi no problems when the ex sold the car with 225,000 mi a year ago and it is still running strong a year later.
I understand that a stick will do better in the MPG dept, but swapping same for same would be a lot less work.
Since dropping 1 to 2 thousand on an overhaul is not gonna happen, I would like your opinions on what I should do if I opt for the used auto trans. If I go this route I probably will add an additional cooler, pan drain and run synthetic fluid. I will probably also install at least a new front seal.
If I go the other route and opt for the stick shift, what are the pit falls here? anyone actually done the swap? (I have heard about the three plastic plugs)
Thanks,
Roger
Getting an A4LD from the salvage yard is kind of a gamble, since it also has reliability problems behind an Aerostar, though it's better than the 5 speed. You can check the mileage of the van, and the condition of the transmission's fluid, before picking it up.
But the things you plan, auxiliary cooler and synthetic ATF, will help a new or newly rebuilt transmission last longer.
Other than the leak from the 3 rubber plug problem, the stick shift seems to be more reliable than the automatic, and stick shifts will usually give some warning of impending doom by whining, growling or having difficulty shifting gears. Additionally, when they do fail, the failure is usually easier and cheaper to fix
I note that the A4LD had reliability problems in any application, but not as bad as the AXOD used in the Taurus. The transmission failure is why I got this van for $100. So far I have found a used A4LD for $400 with a 100 day warrantee
Increasing the reliability was my intent, but are you suggesting that the same things would not help a used unit also?
For under $1000 in parts you can make the A4LD nearly bulletproof. How many parts depends on what the trans actually needs. The primary areas to focus on are the valve body, and soft seals, and the friction surfaces, but all moving parts need to be checked, and replaced if they are damaged. This dollar figure is on the high end too, and you don't need to build it up that high. You can probably get by with a milder build.
If you do want to swap another A4LD, aim for a 1994 4.0L model. Each year has internal revisions and tougher parts, the last year of the A4LD was the strongest. I would still rebuild a used unit before putting it in, but in this case, I don't see a point in doing so. The primary benefit of this approach is that you can drive the vehicle while you take your time rebuilding a spare, but from your OP, the van isn't drivable right now anyway.
So why not save the $400 of buying a used one and put that money towards making your existing one stronger? In the long run it is a lot less expensive.
Here is a parts list of the primary things you should get to build a stronger A4LD.
#A4LDS. A4LD SuperSize Performance Servo for second gear and overdrive. You need 2 per transmission. This has been needed for a long time. Cost $29.00
#A4LDPV. A4LD oversize pressure boost valve (1985-1994). When rebuilding high performance or heavy duty A4LD transmissions, it is common to find the boost sleeve in the valve body worn. This wear causes low line pressure, soft upshifts, delayed reverse and poor modulator control, resulting in poor performance or premature failure for your high performance or heavy duty rebuild. These complaints can often be caused by a worn boost sleeve, which allows reverse and/or TV pressure to cross leak or exhaust. Cost $35.00
Sonnax Part Summary
The OE springs in many Ford transmissions wear or become fatigued causing low baseline pressure. OEM replacements are hard to find, and many aftermarket springs have unacceptably high spring rates. The Sonnax “elevated pressure” main pressure regulator springs are intended to provide a minimal baseline pressure increase (approximately 10 PSI over OE baseline pressure), enough of an increase to help restore full line pressure. The springs may be used to replace worn OE springs and also to correct low line pressure caused by worn transmissions. This price is for 1 spring. Cost $2.00
#4R. A4LD / 4R44E / 4R55E / 5R44E 4 liter torque converter with furnace brazed fins. Cost $199.00
or
#4R2. Performance A4LD / 4R44E / 4R55E / 5R44E torque converter with furnace brazed fins, all bearing construction, hardened splines, no core charge and comes in stall speeds of 1800 to 3000 RPM. Cost $349.00
#TA4LD. A4LD / C3 / 4R44E / 4R55E / 5R55E / 5R55N Pump Gear Alignment Tool. Always use a pump gear alignment tool when setting up your A4LD type pump or severe pump, pump gear and converter hub damage will occur. Cost $69.00
#5-A4LD. Fits A4LD / 4R44E / 4R55E - 1985-1996. Alto direct clutch PowerPack, adds 1 extra clutch. If you have 5 clutches now you get 6. If you have 6 clutches now you get 7. Will not work with a 4 clutch drum. Cost $56.00
#5C. Fits A4LD / 4R44E / 4R55E - 1985-1996. Carbon Fiber bands for 2nd and overdrive. Two required per transmission. This band will have firm shifts. Cost EACH $25.00
#5B. Fits A4LD / 4R44E / 4R55E - 1985-1996. Alto Red Eagle bands for 2nd and overdrive. Two required per transmission. Cost EACH $17.00
#A4LD-B. A4LD Rebuild Manual. Cost $28.00
A4LD Rebuild Kit 1990 - early 1995, Cost $88.00
#56000. A4LD 6 bolt crankshaft spacer for the 2.8, 2.9 and 4 liter. This is the torque converter pilot bushing that goes bewteen the crankshaft and flywheel. The stock part is prone to cracking. The Sonnax part is made of better steel and has a 1/16 of an inch deeper pilot area to support the converter better. Cost $15.00
All of these are on A4LD Performance Transmission and Parts from PATC, A4LD. You may not need all of the above, and if anyone knows where to get some of it cheaper, thats great too, but as you can see, these parts are for the most part not expensive.
A little personal experience here. I inherited my Dad's 94 Taurus. At about 25k mi. an ATF leak was noticed and repaired. $125. The tranny guy said that we were luck to have caught the leak right away as those transmissions die quickly if the fluid level drops.
At 50k mi. the aluminum piston cracked and upon checking the same pan leak had recurred. The estamate was $2100. about the value of the car with a good transmission. Upon inquiry, I found out that $900 of that was to R&R the trans, so I did that myself. (Not fun.) I dropped off the trans on Monday morning and on Friday morning I get a call and the job is going to be a little more involved then they thought. When I got there they had the trans all torn apart on the bench and had got the parts and labor back up to $2,000.
I finally opted to get a used one and paid $400. My now ex-wife sold the car a year ago with 225k mi. and it is still running around town. It still burns me that the trans shop charged me labor to not only do the tear down, but also to put the thing back together.
For me right now money is really tight, so there is no way I will be forking out anywhere near a thousand bucks to get a $100 car on the road. I figure the van if it ran well would probably be worth about $1,200. If I went for the $400 used one and a couple of minor fixes I will make a few bucks. If I drive it for 2 years and sell it, the price I get would probably be the same. The profit however will be in the use I get out of it.
If for example I go for the used transmission, it might very well have been overhauled sometime within the past 4 years and then I win . If I install it and it is a dog, then I am out my labor to R&R the trans twice but the odds are with me that I won't get two dogs in a row.
This is great info.
The truck is already 20 years old, and has 150k miles. Where does the "long run" end? For an example I really liked the old Econoline vans from the late 60's and early 70's. I had a 72 I sold around 1990 and only rarely do I see them around. I figure this Areostar might be good for another 50k to 100k miles, either for me or someone else.
Don't get me wrong, the information you provided is great, and if this was a low mile later model that I was looking to get 10-12 years out of I might go that route. I however am not in love with this truck, so I am going to roll the dice on the cheep side.
The 4 liter engines were never offered with a manual transmission on either the Aerostar nor the Explorer, due to the only manual transmission that will fit, the M5OD, not being strong enough. The two Bronco IIs I have personal experience with using this engine/trans combination were both grinding in 5th gear. I don't have any experience with them in Rangers.
Also, a good auxiliary cooler will help any working transmission live longer. I meant to say that putting it on a new transmission minimizes heat related problems from day 1, while most used transmissions probably sustained SOME heat related damage already.
I know not all of us on this site have the shop room and the knowledge to rebuild their own tranny and I know money is tight, but to me it's a no brainer.
