Sponsored by: Kumho
Brake bleeding problem
Old Jun 24, 2006 | 10:19 PM
JJayP's Avatar
JJayP
Help!
I have a 1986 F-150 2wd and I replaced the brakes about two years ago. I didn't do the master cylinder at that time, though I probably should have just done it when I had everything else torn up. I did cylinders, caliphers, shoes, discs, rotors and drums (turned).
Two weeks ago, my dash brake light wouldn't go out, and I noticed leakage from the master cylinder at the mounting point.
I replaced the cylinder with a rebuilt. I Bench bled the cylinder before mounting. Then I tried to bleed the system starting at the right rear. I am using a tubing and bottle NAPA tool. All of the wheels are ok except the left rear. I keep getting bubles in the bleed line no matter how much fluid I pump through.
I went back to the master cylinder and bled it with plastic barbed fittings and tubing, puming the fluid back into the reservoir.
Then bleeding again, and same story, left rear bubbles.
I see no evidence of leakage anywhere.
Any ideas anyone?
Jay
Old Jun 25, 2006 | 12:52 PM
someday's Avatar
someday
it could just be air coming right from the bleeder screw...dont loosen the bleeder too much...have u taken off the drum to do a full inspection of the wheel cylinder?
Old Jun 25, 2006 | 02:40 PM
JJayP's Avatar
JJayP
Thanks for the reply. I will pay attention to the bleeder screw. I did pull the drum and didn't see any obvious leaks at the cylinder. The other think that I forgot to mention is that if I remove the cover on the master cylinder and have someone pump the brakes, I get a little geyser of fluid in the rear brake reservoir. According to my Ford manual this is one of the diagnostic indicators that I have air in the lines.
Jay
Old Jun 25, 2006 | 07:22 PM
someday's Avatar
someday
im no expert on the subject, but since u bench bled it again with the same results i would get another mc
Old Jun 25, 2006 | 07:42 PM
stuart1's Avatar
stuart1
Did you do this?
Old Jun 25, 2006 | 08:53 PM
someday's Avatar
someday
i missed that it was a 86...i have the newer versions were that is not necessay
BigMikeUGA
May 3, 2012 02:11 PM
walkman
1983 - 2012 Ranger & B-Series
Jan 14, 2009 06:36 AM
wejones
Feb 23, 2008 12:41 PM
BigSix1
Nov 24, 2004 09:59 AM
restorit
1978 - 1996 Big Bronco
17
Mar 26, 2002 11:07 PM
